2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
can you really?
Old Jan 30, 2013 | 02:59 AM
Ryancobaltss's Avatar
Exclamation can you really?
so for the past few days i have been helping a buddy of mine out with installing a turbo on his 2.2 ecotec cobalt. 08 model and he didn't want to tap his engine for the oil feed/drain lines so instead hes gona use an oil catch can to use it like a ''mini'' oil tank for the turbo and just have the lines go to the tank instead of the motor how bad could this turn out? LOL
Old Jan 30, 2013 | 03:03 AM
08baltSS's Avatar
Not trying to ask a stupid/uneducated question (even though I probably am), but how will the oil cool down?
Old Jan 30, 2013 | 03:08 AM
Thats what i was thinking at first and he told me oil cooler. but then he would need a stand-alone oil pump to get it around the lines i think?
Old Jan 30, 2013 | 03:14 AM
08baltSS's Avatar
Yeah, for sure. Seems a little illogical to me lol.
Old Jan 30, 2013 | 03:19 AM
im gona have him look at this post in the morning XD im pretty sure he's thinking that if a ''pro-charger'' doesn't need oil lines then a turbo would be like the same thing lol but pro-chargers are no where near the heat of an exhaust.
Old Jan 30, 2013 | 03:50 AM
nwss's Avatar
why doesnt he just drain it into the oil pan and dont all ecotecs has 3 or 4 taps on the front or back side??
Old Jan 30, 2013 | 04:01 AM
armcclure's Avatar
Yes
Old Jan 30, 2013 | 04:06 AM
nwss's Avatar
post pictures!
Old Jan 30, 2013 | 12:13 PM
rcarr0327's Avatar
only thing you have to tap is oil pan for return line or buy a bung and weld that in. you dont need to tap the block for oil, there are 3 spots on the front and back under the head behind the coolant hose that you can use.
Old Jan 30, 2013 | 12:17 PM
LS6Rally's Avatar
AFAIK the oil catch can will not work. if you go that route, take a video, i dont think that turbo will last 15 minutes
Old Jan 30, 2013 | 12:21 PM
user 72239's Avatar
in b4 blown turbo
Old Jan 30, 2013 | 12:26 PM
buildmeanempire's Avatar
Bye bye turbo. Hey, tell your friend if he is down with wasting money to send some my way.
Old Jan 30, 2013 | 12:28 PM
user 72239's Avatar
do it right or dont do it at all. hes just being lazy. just tap the damn oil pan
Old Jan 30, 2013 | 01:29 PM
EXsoccer1921's Avatar
not sure if trolling....
no, that is not going to work at all. a "catch can" does not actually contain oil. nor is it ever filled with oil to act like a reservoir. and what it IS filled with, i do not want running through my turbo.
Old Mar 20, 2013 | 04:25 PM
2009CobaltLT's Avatar
He wasnt really referring to a 'catch can' as much as a reservoir from what it seems. It looks like he wants to run a full oil circulation setup separate from the engine, which would probably work fine. but there is no point in doing that as it is much simpler to pull a galley plug off the back of the block for oil feed and drill/tap pan for oil return
Old Mar 20, 2013 | 08:25 PM
nhanson's Avatar
******* idea.
