2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Dc front strut bar not fitting >:(
Old Aug 2, 2012 | 06:16 PM
Ceej's Avatar
Idk if I'm doing it wrong, but this **** is not fitting. I need like a 1/4" more over to make it fit, and it just won't go. Any advice?
Old Aug 2, 2012 | 06:20 PM
LS6Rally's Avatar
isn't your car a TC?
Old Aug 2, 2012 | 06:23 PM
Ceej's Avatar
No. LT
Old Aug 2, 2012 | 06:26 PM
LS6Rally's Avatar
hmm. i know i used a rubber hammer to coax mine on. i have an ARK, but its pretty similar.
what wont it clear to go on?
Old Aug 2, 2012 | 08:48 PM
Ceej's Avatar
The inner stud on passenger side
Old Aug 2, 2012 | 09:38 PM
LS6Rally's Avatar
take a chisel or big screwdriver and open up the opening just a little bit. you're talking about the slotted side correct?
Old Aug 2, 2012 | 09:49 PM
BlackLsCoupe's Avatar
ram a truck into the side of it. problem solved. JK i think if you have a comealong chain you could ratchet it till it sits on the bolts and tighten it.
Old Aug 2, 2012 | 10:02 PM
Ceej's Avatar
Ended up giving it a little bend, and with an assistant we banged it in. Victory!
Old Aug 2, 2012 | 10:48 PM
carstedt's Avatar
mine had the same issue i had to jack 1 side of the car up and it ended up fitting then for sum reason lol
Old Aug 2, 2012 | 10:56 PM
Ceej's Avatar
yeah cause you adjusted the strut jacking the car up
Old Aug 2, 2012 | 10:58 PM
carstedt's Avatar
idk sure..go ahead and maybe try that maybe ull hav sum luck
nvm i read u got it already my bad
Ceej's Avatar
I might have to if I ever need to take it off lol
bigdeertz
Nov 17, 2016 09:41 AM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
