2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
different valvetrain noise
Old Aug 1, 2011 | 10:35 PM
rcarr0327's Avatar
I know there is a lot of threads about valve train noise and a lot misconceptions but i cant find one situation that is close to mine. When my car is warmed up it makes a loud almost knocking noise for a few seconds then bogs low and clears the noise. Vince at Trifecta said that my knock sensor is reading something but is most likely NOT rod knock. (Rod knock is typically heard when engine is cold). The noise doesnt happen on initial start up and i think it has something to do with oil pressure getting to the lash adjusters or roller followers or something on top of the motor because when i get in my car and start driving after its been warmed up it doesnt make the noise. Please let me know what you think. Thanks guys
Old Aug 1, 2011 | 11:27 PM
Powell Race Parts's Avatar
Difficult to say, but I would suggest an updated timing chain tensioner if you have not changed that. available from CED not expensive and easy to replace. remove and put in new, u be good.
Old Aug 2, 2011 | 12:02 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
This. Sounds like the Timing Chain Tensioner is dying.
Old Aug 2, 2011 | 07:43 PM
rcarr0327's Avatar
alright, so i got a tensioner and put it in and no dice i took a video of what im dealing with and heres the link: ‪Cobalt "knocking" noise‬‏ - YouTube
i dont really know where to go from here :/ i wanna take off the valve cover and run the car but i also dont wanna get sprayed with boiling oil. any suggestions will help, thanks guys
Old Aug 2, 2011 | 10:15 PM
Take off the valve cover and inspect all your lifters/rockers, as well as the cam. Make sure the chain is tight... probably be worth making sure its timed correctly, as well... but if the issue is only there when the car warms up, then that shouldn't be the case. (If you DO check the timing... don't rely on the colored links, they aren't always correct.)
If all checks out well up top... you're probably going to need to drain the oil, drop the oil pan, and check the rod bearings.
Old Aug 2, 2011 | 10:22 PM
rcarr0327's Avatar
yea i know its timed correctly cuz i got retimed back in the spring and its all good now. but yea im probably gonna check under the valve cover again. u think rod bearings could be the problem? ive heard it happen on a cold start every once in a while but not as nearly as loud and for less than a second. what would be wrong with the bearings for it to be making that terrible sound at operating temp, thanks man.
Old Aug 2, 2011 | 10:48 PM
Maven's Avatar
hard to tell for sure from the vid but it sounds like timing related to me. have you had the oil pan off this car? if so issue could be excess rtv stuck in oiling system.
Old Aug 3, 2011 | 07:42 AM
rcarr0327's Avatar
Yea i took the oil pan off in winter to put the new one withali the return line bung. I don't think its timing cuz like USMC said it would be happening all the time :/
Old Aug 3, 2011 | 05:03 PM
rcarr0327's Avatar
alright, well today i took off the valve cover and made a pretty interesting find... my cover for my VVT gear was cracked in half and just chilling there.
everything else seemed to look fine and no scratchy or dry spots or anything. When i started the car the noise was still there. me and my friend think it could be the rest of the plastic ******* around in the bottom of my timing area but cant see until i take off cover. any other suggestions? thanks guys
Old Aug 3, 2011 | 05:24 PM
Maven's Avatar
See........timing related
Old Aug 3, 2011 | 10:34 PM
rcarr0327's Avatar
^^^lol if only that solved my problem. i think i still need to find that other half......... lol
Old Aug 3, 2011 | 10:43 PM
wow that sucks for you. at least remove front cover and look for trash and correct damage if any. Its a pita job.
Old Aug 4, 2011 | 07:35 AM
rcarr0327's Avatar
yea thats the plan, my buddy has a lift so it will ease the pain of the cramped space but its still cramped as hell in there. i'll keep u guys posted
Old Aug 5, 2011 | 10:22 PM
Take the pan off. There's probably chunks/pieces in the bottom... don't want them clogging up your oil pick-up and starving your engine of oil.
Old Aug 7, 2011 | 09:11 PM
rcarr0327's Avatar
think i should take off my pan or timing cover? or both? thanks
Old Aug 7, 2011 | 09:14 PM
Answer to that question is already in here...
Old Aug 7, 2011 | 09:34 PM
rcarr0327's Avatar
sorry i just like to make sure before going into a bigger project than a valve cover, ill keep u guys posted
Old Aug 8, 2011 | 08:42 PM
rcarr0327's Avatar
alright so i got the the timing cover off and here is what i found. the chain is loose at only one part and looks like the tensioner that is supposed to tension isnt working properly. could that be that its not getting oil?
‪Loose timing part‬‏ - YouTube
Old Aug 8, 2011 | 10:38 PM
Maven's Avatar
thats the balance/waterpump chain. There is currently an issue with the chains and tensioners of the newest 2.4s but its very rare on the 2.2s there is a new tensioner, and the chain gets replaced. they actually make a noise similar to your noise, but is usually only does it with the ac on
Old Aug 9, 2011 | 12:20 AM
rcarr0327's Avatar
Anything you suggest? Im also going to take off the oil pan tomorrow so ill let u know what I find
Old Aug 9, 2011 | 11:13 AM
nhanson's Avatar
can you explain more? with my AC on it sounds like lifter noise almost...only with AC on though.
Old Aug 9, 2011 | 06:19 PM
rcarr0327's Avatar
update:
took of my oil, everything looks perfectly normal and is clean. im thinking it is that loose part on my balance/waterpump chain. anyone know what the tensioner shown in the video is called so i can possibly replace it? thanks
Old Aug 9, 2011 | 06:25 PM
Ecotec Water Pump Chain Tensioner 90537300 - Crate Engine Depot
Ecotec Timing Chain Tensioner Bolt 11588522 - Crate Engine Depot
This chain says its for the LSJ, but I was under the impression that this chain was the same across all... Maven would know for sure.
Chain LSJ Water Pump and Balance Shaft 90537370 - Crate Engine Depot
Old Aug 9, 2011 | 09:04 PM
rcarr0327's Avatar
do u think i need all 3?
Old Aug 11, 2011 | 05:08 AM
Doubt it. I don't think the bolt is TTY, so you should be able to use it again... but don't take my word for it. And if Maven says they replace the Tensioner and the chain... so I would suggest doing the same.
