2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
different valvetrain noise
Old Aug 19, 2011 | 08:32 AM
rcarr0327's Avatar
Replaced the tensioner and everything is still the same. The same slack same noise and same bogging. Could VVT or timing be an issue?
Old Aug 28, 2011 | 05:23 PM
cleanxfe's Avatar
the tensioner and chain look fine when you moved it remember the tensioner works with oil pressure to give it tension on the chain so with out oil pressure it should move freely but have a set preload, the actuator probably broke from poundage on the engine
Old Aug 28, 2011 | 10:30 PM
rcarr0327's Avatar
Hmmm interesting... which actuator do u think?
Old Aug 29, 2011 | 09:45 AM
cleanxfe's Avatar
that part thats broken in your pic is the exhaust actuator which is attached to your exhaust cam gear and that controls vvt the intake has the same thing aswell
Old Apr 15, 2012 | 11:50 PM
rcarr0327's Avatar
lol sorry i just got back to this. but you're saying that plastic piece that was snapped in half is what actuates the VVT?
Old Apr 16, 2012 | 04:59 PM
rcarr0327's Avatar
i know that big piece on the actual gear is the actuator but the thin piece that broke off just looks like a cover. i would be throwing a code if my actuator wasnt working
Old Apr 16, 2012 | 08:06 PM
cleanxfe's Avatar
yes you would throw a code if actuator is f'd
Old May 7, 2012 | 04:58 PM
rcarr0327's Avatar
UPDATE!
I think it could be my lash adjusters or oil pump not providing enough oil to them, I have never thrown a low oil pressure light so im leaning more towards adjusters. any suggestions?
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
