the DUAL EXHAUST!
Any one here have any thoughts??? thanx
ok thats what i was wondering cause the Y pipe would be put in almost at the very end of the exhaust. also one more question going catless and have a header would also hurt in the HP zone? basicly straight piped with a header ;p
U drive a base model and ur name is ss? Lol. Ur exhaust is mad fail.
I also find it hard to believe u have 171 hp in a stock 2.2 with a strait pipe
Yes, your car would lose all back pressure. Which is bad on a NA car.
im getting duals fabbed up for my ss/tc when i go home in march from iraq. i have teh monies and everything. so now its just a waiting game. lolz. its only for the looks tho, i dont expect gains out of it. just gunna fab up a Y pipe and weld it in.
This may be a very noob like question but I am trying to learn as much as I can about the different upgrades or performance parts for the cobalt. But why would putting a dual outlet exhaust hurt a N/A engine? How does it rob it of HP? Would a dual outlet exhaust have any negative/positive effect on a Forced induction engine?
I just got my 2nd cobalt, my first one was totaled in an accident and I am more interested in performance upgrades this time around. I couldn't find a cheapish SS around me, actually there wern't many in my area to begin with so I settle for a 2009 Cobalt Coupe LT. Basically all the questions I asked are directed towards the LAP(2009 cobalt correct?) engine.
I completely agree with 06_cobalt. for instance, my fancy dancy truck i got for six hundred bucks which now has a small block v 8 should have 3 inch exhaust true duals. ( oh noes I does has it) with two cherry bombs, one for each side. but a cobalt, that's a no go. there's no real need other than looks to put dual outlet exhaust on a cobalt.
Dual exhaust = loose power
loose power = loosing races
loosing races = bad reputation
bad reputation = dual exhaust
Its all about logic
I did some Enstein lmao
or is it someone else xD idont know
Its all about logic
Thank you for showing my errors but i dont see where being lazy, or for you "errors", count as not being Einstein!?
And I didnt say i was him, just said i did some logic and he was good at it.
But oh well haters will stay haters haha
for a car with only one possible way to exit exhaust, dual pipes wont really gain you anything. The only time when it does is if you run a v6 v8 or v10 or v 12 motor, an inline motor wont gain from a dual exhaust. and when you run a v motor, what you're looking for is where to put the h pipe to cross between the two exhausts, at that calculated point you will gain the most power per pipe. If you're running an inline motor with only one pipe coming out, then you have no reason to split it into two pipes other than looks. I did all the research on this topic a couple months back when i put dual exhaust on my truck.
z28addiction
Sep 28, 2015 12:03 AM
