2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine problems
Old Sep 30, 2011 | 03:04 AM
Mr.09cobalt's Avatar
Engine problems
I just put a new bad mab header on my 2.2 and now the engine stalls out sometimes the rpms jump. theres a huge hole in my flex pipe but that will be replaced with my new downpipe zzp. but coul;d it by chugging because of the 02 sensers not getting enough air?
Old Oct 9, 2011 | 03:27 PM
cobalt2010's Avatar
02 sensor tells ecu if you are running rich or lean, mine was just fine
chances are that hole is ******* with something
Last edited by cobalt2010; Oct 27, 2011 at 10:10 PM. Reason: Automerged Doublepost
Old Oct 9, 2011 | 03:54 PM
05Slowline's Avatar
piston probably has a hole in it
Old Oct 9, 2011 | 09:00 PM
nhanson's Avatar
First O2 should be before the flex in your header. So it shouldnt cause problems
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
