2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
engine rattle
Old Oct 2, 2012 | 03:21 PM
ryananstey1986's Avatar
Exclamation engine rattle
this is the same noise my 2009 G5 2.2 makes....dealership is after replacing cam phasers and timing chain and timing chain tensioner and it still making that rattle. Any idea what it could be.???? the rattle only lasts about 2 or 3 seconds like in the video..
2011 Chevy Equinox 2.4 start up noise - YouTube
Old Oct 2, 2012 | 04:04 PM
anyone?
Old Oct 2, 2012 | 04:07 PM
Ceej's Avatar
Sounds like something is getting stuck...
Old Oct 2, 2012 | 04:16 PM
like what???
Old Oct 2, 2012 | 04:40 PM
Ceej's Avatar
Do you have any mods? Does it throw any codes?
Old Oct 2, 2012 | 04:41 PM
no codes and all stock
Old Oct 2, 2012 | 04:48 PM
Ceej's Avatar
Im not a mechanic, but it sounds like either the throttle body is getting stuck, or something is knocking in the engine
Old Oct 2, 2012 | 06:16 PM
this is another video of the noise im having in my 2009 G5 2.2 ...all stock and no codes....already replaced cam acuators and timing chain and tensioner.....2011 Equinox noise on start-up - YouTube
Old Oct 2, 2012 | 07:11 PM
Old Oct 2, 2012 | 08:52 PM
cleanxfe's Avatar
those videos of the equinoxs there issue is 1. direct injection fuel pump 2.def low on oil and oil is dirty gm f'd up the olm duration on the 2.4l engine got 3 in the shop replacing the engine for oil consumption problems but only the equinox...how often do you go between oil changes?
Old Oct 3, 2012 | 05:08 AM
5000 or 6000 kilometers
Old Oct 3, 2012 | 03:57 PM
that engine noise is pissin me offfffffff
Old Oct 3, 2012 | 07:34 PM
cleanxfe's Avatar
check the cam actuator solenoids for debris on the screens dealer should have checked them cause there is a bulletin for it
Old Oct 4, 2012 | 05:13 AM
they replaced the cam acuators already and still making the rattle..
Old Oct 4, 2012 | 01:21 PM
cleanxfe's Avatar
no no the solenoids they are on top they look like two tubes with connectors on top of them
Old Oct 6, 2012 | 07:10 AM
how do u take them out? theres one 10 mm bolt on each one and i removed the 10mm bolt and it wouldnt come out. Is there a technique for taking them out??
Old Oct 6, 2012 | 11:52 AM
Old Oct 10, 2012 | 05:08 AM
Old Oct 14, 2012 | 01:35 PM
how do u take them out i removed the bolt on each one and they wouldn't come off?? can someone post a how to or a pic or a video?
Old Oct 14, 2012 | 01:40 PM
FrossB's Avatar
Thread Killer
take the bolts out. they have an o-ring type seal that may take a little force to pull out. try to pull them straight out tho without side to side movement
HEATON
Oct 16, 2015 07:21 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
