2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine/Trans Problems? Help please
Old Nov 11, 2011 | 11:46 PM
09Sp0rt's Avatar
I just started to notice this about an hour ago. When I give it a little gas it doesn't pull as “hard” as it should and when I get in to 3rd gear it seems like the engine is just revving and I'm not speeding up. No cel's or anything, no codes (I don't think, not sure how to check) only mod to the engine is a k&n typhoon that I had installed in the summer. Car is a 2009, I'm automatic as well. Any help is greatly appreciated.
Old Nov 12, 2011 | 07:31 AM
09Sp0rt's Avatar
Old Nov 12, 2011 | 08:34 AM
Dart_SI's Avatar
Could be a trans issue. Unfortunently most of this forum including me has no idea how auto trans works. Lol. Sorry.
Old Nov 12, 2011 | 08:37 AM
mmcgee123's Avatar
trans is prolly slipping id check fluid level and condition low fluid level can cause alot of weird things to go one with a auto trans ie hard shifts or slipping irractic down shifiting etc how many miles do you have on it
Old Nov 12, 2011 | 09:38 AM
09Sp0rt's Avatar
It's only got 31k on it, my mind is just blown about no cels or codes...
Old Nov 13, 2011 | 07:18 PM
cleanxfe's Avatar
warrenty!
Old Nov 13, 2011 | 08:30 PM
nhanson's Avatar
Maybe you just think its going slower?
Other gears work fine?
Old Nov 13, 2011 | 08:54 PM
09Sp0rt's Avatar
Other gears work fine, but its definately not just me. Something is jacked up.
Old Nov 20, 2011 | 09:24 PM
rcarr0327's Avatar
hmm if it was stick it would sound like a bad clutch. im not much a trans guy but id say check fluid or even just change it
Old Nov 20, 2011 | 09:32 PM
nhanson's Avatar
vid of problem?
Old Nov 25, 2011 | 01:15 AM
Validater's Avatar
I second warrenty. dont even bother trying to fix it. an air intake will not void warrenty, if you feel like the dealer will be a dick, throw the stock one back on, but bring it in. cause checking the fluids is a pain in the ass when GM made the auto trans fluid to last the lifetime of the vehicle. aka no dip stick.
So unless your mechanically inclined, take it in for warrenty.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
