2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Full service
Old 01-09-2014, 03:00 PM
unijabnx2000's Avatar
Full service
I want to change all my fluids in my car and im hoping someone has a link to the service manual so i can look up what fluids I need to buy.
So far the only thing im sure i'll have to get from the stealership is transmission oil.
09 Cobalt LS XFE 5spd
Old 01-11-2014, 02:45 PM
andrewcarr1993's Avatar
I put in Royal Purple Max ATF for my 09 XFE, F23, apparently they switched to all automatic transmission fluid after a certain year so when building them they only have to use one kind for everything.
As for the other things I'm not sure, there is a how to I found by searching, I believe it was of a different site though.
Old 01-27-2014, 08:15 PM
LotusRenaultF1's Avatar
Any ATF-4 fluid can go into the tranny, as said above they don't use gear oil after I think 2006 or 2007 for convenience. I'm assuming you don't have your owner's manual so I won't suggest looking there for the fluids but you can probably just type in whatever fluid into the search forum thing and it'll bring you to a helpful thread.
Old 01-27-2014, 08:32 PM
06_cobalt's Avatar
Coolant is Dexcool, Brake fluid is DOT3.
Old 01-27-2014, 08:47 PM
Xmetalhead2003X's Avatar
Amsoil atf in my f23. Motor gets amsoil signature 0w30 with their ea filter. Pleased with results so far on 15k change interval. Dexcool for coolant. Dot 4 can be used for brake fluid. Most companies now market brake fluid as dot 3/4 as 3 is becoming obsolete. Higher boiling point, same function.
patooyee
10-15-2015 05:11 PM
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
dieGone
10-01-2015 06:27 PM
importkiller
09-30-2015 07:18 PM
Quick Reply: Full service
