Gene's 2.2 LAP Supercharger Build
duuude...you need to read what i say. The 1bar MAP from a ss/sc fits directly in the hole on the LSJ IM, unlike the one that comes stock on a 2.2/2.4 which is too small. All you need is a way to hold the lsj 1bar down and you're good. If you use the 1bar from the 2.2/2.4, you have to worry about keeping it down so tight there isnt a boost leak.
Ok, I didn't mean to upset anyone. I've just got some new parts I ordered at my desk at work and I didn't want to purchase until I figured it out.
I would rather not do any cutting or splicing if not necessary, so I'll get the LSJ 1 bar map. I'll have to figure out how to hold it down... does anyone have any ways... or descriptions on what they did to hold it down?
Also, I could swear the LSJ 1 bar map looked like it had a different connector than my map, but I'll double check.
#40
Well today the powdercoater of my supercharger sent me a quick picture as it was cooling down from being in the oven.
Here are some before pics and todays pic. The black coating may not look bad in the pics, but it was terrible, with runs and was painted while it was on the vehicle by the previous owner, so it wasn't even covering in some places. I took it all off with acetone last Sunday and shipped it out to the PC.
#43
Thanks guys. I chose that color because that is the color I powdercoated my calipers and also pretty much the same color as I'm having my interior trim painted.
I will be sending out the valve cover as well. Should be fun!
Here are the parts that I've purchased so far. Only a couple more used parts to go!
GM Parts
LSJ TB To SC Bolts (4)
LSJ TB Gasket
LSJ Supercharger Gasket
LSJ IC Pump Insulator
LSJ Intake Manifold Gasket
LSJ Stage 2 Serpentine Belt
LSJ 1 Bar Map Sensor
LSJ Upper Radiator Hose
New Parts
ZZP Heat Exchanger
OTTP SS SC Pulley Bolts
GlowShift Vacuum | Boost Gauge
AEM Wideband Air | Fuel Ratio Gauge
OTTP 3.0 Polished Pulley (For Stage 2 Hub)
M-8501-L54 Ford Racing Intercooler Pump
Used Parts
Eaton M62 Supercharger
GM Stage 2 Injectors (42lbs)
Stock LSJ Air Intake
Stock LSJ Throttle Body
Stock LSJ Serpentine Belt
Stock LSJ Intake Manifold
Stock LSJ Supercharger Pulley
GM Parts
LSJ TB Gasket
New Parts
ZZP Heat Exchanger
Used Parts
#44
So just an update here.
Hunterkiller89 is a major help and I very much appreciate it.
He pointed out today in another thread about the vacuum hoses and some questions I had.
So on the LAP:
Brake booster hose goes to the intake manifold. On the LSJ the brake booster hose goes to the supercharger. So, we will need a brake booster to supercharger hose from the LSJ. I have to imagine that you could use some standard vacuum hose, but I am going the GM route as I want my car to be done with factory stuff.
On the LSJ TB that vacuum hose goes from TB to evap solenoid. The LSJ and LAP evap solenoids are the same, so all you need is that hose.
On the supercharger bypass actuator there are two nipples. The top hose goes to the small nipple on the supercharger and the bottom one gets left open on our vehicles.
My next question was going to be where to hook up the mechanical boost gauge and he was nice enough to already answer it and say that it gets hooked up to the small nipple on the LSJ intake manifold.
Also, on the LAP, all of our cars have secondary air injection, so I will be purchasing the LSJ Header and the LSJ DP to get rid of that.
Been ordering parts all weekend, lol.
So on the LAP:
#45
haha you really got this thing figured out pretty well. Just an FYI, you CAN use the stock brake booster hose, as it will reach the SC. Its just gonna be tight. A slightly longer hose would be an easy fit, but (ive heard) its a pain in the ass to reach the other end of that hose where it hooks in to the brake booster
#47
From looking in the service manual, the LE5 already has the 8 pin TB connector, but the L61 does not. I ordered the connector today. It retails for $150 and I believe my price is around $85.
Oh well, I don't have a choice!
#48
Gene when's your ETA on being done? Me and Rob are kinda racing, although I've pretty much already conceded defeat since he's beating me in parts about 10-fold.
