2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Gene's 2.2 LAP Supercharger Build
Old Feb 6, 2010 | 12:03 AM
  #526
Gene Culley's Avatar
Talking
Originally Posted by Army-Cobalt
Very nice. Just read through everything and you sir inspire me, Gene. My 2.2 LAP is sittin stock and I needed some inspirational reading material. Very sexy engine bay as well.
Thanks. It was a fun project and the end result was really good. I just have to get the clutch fixed.
Old Feb 7, 2010 | 06:25 AM
  #527
Jonah Gogel's Avatar
Anyone have any good hints on what kind of turbo to put on my LAP 2.2? I want a autocross/drag/daily driver. Basically im new to the forum and im tryin to get sponsered by a company.
Old Feb 7, 2010 | 06:42 AM
  #528
unijabnx2000's Avatar
anything from a GT2860RS to a GT3071R.
Depends on if you want power or response.
go research!
Old Feb 10, 2010 | 06:58 PM
  #529
4dr-RS's Avatar
ok so im gonna buy the lsj header but i it looks the same as my stock 2007 l61 manifold....heres the pic of my stock l61 header
and heres a pic of a stock lsj header, they look so similar!
SOMEONE PLZ TELL ME THE DIFFERENCE BEFORE I BUY IT! lol
note: the lsj header was painted black
Old Feb 10, 2010 | 07:01 PM
  #530
MP81's Avatar
It's bigger.
Old Feb 10, 2010 | 08:20 PM
  #531
ebristol's Avatar
Originally Posted by MP81
It's bigger.
Does anyone bother to search anymore?
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/2-2-w-lsj-exhaust-manifold-72156/
Old Feb 11, 2010 | 12:44 PM
  #532
BULLETSSMOKE's Avatar
that dp looks massive compared to the 2.2. in stock to stock comparison..
Old Feb 12, 2010 | 10:36 AM
  #533
Illini_06SS's Avatar
You can't really get something that's good in all 3 unless you plan on swapping out parts/tunes every weekend.
Old Feb 16, 2010 | 09:50 PM
  #534
Talking
This is correct. If you have them side by side you'll notice the difference... much.
Old Feb 24, 2010 | 11:00 AM
  #535
BALLIN450's Avatar
map sensor
i have a s/c 2.2 in a j body and my maps on intake manifold and i turned out a plug on the leathe for the supercharger hole u dont need to run that one it is a barametric press.switch not needed
Old Feb 24, 2010 | 12:29 PM
  #536
HunterKiller89's Avatar
punctuation can do wonders for sentence comprehension
Old Feb 24, 2010 | 12:33 PM
  #537
DarkCobalt13's Avatar
It's only going to get worse my friend.....
Old Mar 5, 2010 | 04:06 AM
  #538
Turbo setup
What ALL do I need. You told me what kind of turbo, but what are the parts i would need? Obviously i would need a kit, but where do i go with the electrical and what engine modifications would i need? I was wanting to comp cam it, put in some 9.5:1 pistons and rods, flywheel, clutch, and ect.. Please anyone help me i would appreciate any kind of help thanx and god bless!
Would the car still pass emissions?
Last edited by Jonah Gogel; Mar 5, 2010 at 04:06 AM. Reason: Automerged Doublepost
Old Mar 21, 2010 | 10:04 PM
  #539
MP81's Avatar
I'm sure a turbo thread would be a better place to ask that...
Old Mar 22, 2010 | 01:26 AM
  #540
Mr.N00bLaR's Avatar
Take a look at what other people have done....:
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/l61-lap-turbo-super-forced-induction-build-thread-208355/
Old Apr 15, 2010 | 08:37 PM
  #541
Talking
So spring is here and my tune isn't so well, lol. Got to get Vince to retune me. Clutch is still in bad shape. Need to get another one.
Old Apr 15, 2010 | 08:41 PM
  #542
redcobalt07's Avatar
didn't you upgrade your clutch already?
Old Apr 15, 2010 | 09:00 PM
  #543
odd. i ran mine for a year and a half unchanged. buuut i guess every car's different
Old Apr 20, 2010 | 08:03 PM
  #544
Talking
I never got a clutch. It got cold here and snowing so I drove the Hummer. I can daily drive the car, but if I want to punch it to pass someone or push the throttle down at cruising the clutch starts slipping pretty bad. It didn't do that until I installed the cold air intake and the 2.9 pulley.
I ordered a Spec Stage 2+ clutch today. We'll see what happens then. It will probably snap an axle.
Old Apr 20, 2010 | 08:20 PM
  #545
i'd get some OTTP or TTR tranny mounts to keep your axles alive. better to prevent spending $800 later by buying $250 in parts now. Course, being a parts dealer, i suppose OEM axles are a bit cheaper for you
Old Apr 21, 2010 | 10:49 PM
  #546
Jn2's Avatar
Jn2
.my stock clutch was on the car for 11.5months...when i took it out after all the slippage i was gettin, the clutch disc was in baaad shape, the rivets were being ground off already...good thing i changed it....im still the process of breaking the excedy stgII in...but so far it doesnt slip at half throttle like the stock one did...i know interview had the spec stg2+ with his 2.8 and it ran good...
i'mm running the TTR poly tranny bushings, had them for quite a while, my car doesnt know what wheel hop is def recommend them
Old Apr 22, 2010 | 04:02 AM
  #547
TTR now makes rotated trans mounts just like OTTP, only a lot cheaper...those would be the best, but the inserts are a good in between.
Old Apr 22, 2010 | 04:22 AM
  #548
SlowBalt_06's Avatar
like most parts you get what you pay for....dont buy a knock offs... you gotta pay to play
Old Apr 22, 2010 | 05:29 AM
  #549
lol, nothing's wrong with them. The OTTP ones arent any better....their price just reflects that OTTP did the research in making them. Just because it wasn't TTR's idea and they didnt have to pay for any research by comparison, doesnt mean its made any less.
Course with your sig i can see where this will go. as far as im concerned TTR made a 100% replica of a known working part and is charging less for it.
regardless, this thread is not about any of this, and merely about controlling gene's wheelhop
Old Apr 22, 2010 | 07:16 AM
  #550
09blackonblack's Avatar
ottp is making rotated mounts for the 2.2 now...
