2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Milk on Oil Cap WTF
Old Mar 2, 2010 | 10:01 AM
jbenso4's Avatar
Milk on Oil Cap WTF
well im kinda mad right now, my car has 8k on it, the supercharger build has not started at all, and it seems like its going to get delayed some more....All i have on the car is an Injen Intake and a cat back system.
I go to do my second oil change, take off the oil cap and see the dreaded milky substance which only means nothing nut moisture in the oil....the question is how? I do not beat on the car at all and I cannot imagine that the headgasket is blown already....Should I take it back to the dealer?
Old Mar 2, 2010 | 10:03 AM
DoMiStIc_RuSh_06's Avatar
Could just be condensation tho.... From being really hot then really really cold
Old Mar 2, 2010 | 10:05 AM
jbenso4's Avatar
That could be true...I only drive 1.5 miles to work in the morning.....sometimes do not let the car warm up all the way.
Old Mar 2, 2010 | 10:09 AM
lwrs10's Avatar
that is the reason right there....the engine does not get warm enough to evap the moisture in the crankcase. Wipe it off and go for a long drive.....that will fix it.
Old Mar 2, 2010 | 10:12 AM
jbenso4's Avatar
so were thinking there really isnt anything to worry about?
Old Mar 2, 2010 | 10:16 AM
Nope....I wouldn't worry about it
Old Mar 2, 2010 | 10:17 AM
jbenso4's Avatar
thanks alot guys....big weight off my chest.
Old Mar 2, 2010 | 10:18 AM
lwrs10's Avatar
I wouldnt worry about it....but at least try to take your car for a good drive once a week or so to give it a chance to get rid of the moisture.
Old Mar 2, 2010 | 10:19 AM
jbenso4's Avatar
okay..should i worry about the valve cover though?
Old Mar 2, 2010 | 10:34 AM
Illini_06SS's Avatar
As long as the oil in the pan isn't chocolate milk, it's nothing to worry about. Even then, just change the oil and keep an eye on it to make sure it isn't coolant getting into the oil. Driving through high water can cause water to get sucked in through the seals (happens all the time in the differentials of 4x4's when you do a lot of water crossings).
Old Mar 2, 2010 | 11:14 AM
lwrs10's Avatar
no.........
Old Mar 2, 2010 | 11:27 AM
fredds-turbaltSS's Avatar
id say swap your oil just to play safe and keep an eye on it
Old Mar 2, 2010 | 03:57 PM
BlackCobalt707's Avatar
same thing happend to me. it went away
Old Mar 2, 2010 | 04:01 PM
beamer1341's Avatar
this happened to me got worried as **** (thought head gasket) but its it went away last spring when the weather started warming up
Old Mar 2, 2010 | 04:02 PM
redssna's Avatar
I had this recently. Cap looked bad but the oil was just fine when I changed it out. Like they said moisture builds up and if you don't heat the engine up for long enough it just wouldn't full evaporate. Nothing to worry about though.
Old Mar 2, 2010 | 04:09 PM
DarkCobalt13's Avatar
Get her out and put some miles on it. That milky substance will disappear. 1.5 per trip is too short...
Old Mar 2, 2010 | 10:52 PM
jbenso4's Avatar
i wiped it a couple weeks ago and it came back...thats what i was curious about...but it sounds like its just my short commute to work every morning....hopefully will goawaw with warmer weather
Old Mar 2, 2010 | 11:01 PM
scottyguy401's Avatar
Yeah I have that too. I get a lot of milky build up in my catch can
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
