2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Need help ASAP!!!!
Old Jul 26, 2012 | 02:43 AM
Ceej's Avatar
Need help ASAP!!!!
I need the size of the three bolts that connect the header to the downpipe and where to get them. All 3 of badmabs broke >
Old Jul 26, 2012 | 02:52 AM
CobaltItaliano's Avatar
contact brad from badmab and he'll send you some more
Old Jul 26, 2012 | 02:53 AM
Killa SS's Avatar
just grab some bolts and start test fitting. you dont have bolts and nuts an washers around ur house?
Old Jul 26, 2012 | 03:36 AM
LtDanBoostdG5GT's Avatar
I believe that it's 13mm
Posted from Cobaltss.net App for Android
Old Jul 26, 2012 | 09:30 AM
Ceej's Avatar
I'm not using badmabs bolts again, plus I need them ASAP.
Don't have thicker ones laying around the house.
Thanks Dan
Old Jul 29, 2012 | 10:27 PM
Validater's Avatar
My only help to give is my header never came with studs, so re-using the OEM ones caused them to cross thread and shear. 1 is still good and not cross threaded. The other 2 I just drilled the hole bigger and nut and bolt with a lock washer those 2. A full year later and no leaks. (went back to OEM gasket also)
Old Jul 29, 2012 | 10:29 PM
gibsonj4's Avatar
Do these headers just suck? I have read several threads with people having issues with them (cracking, bolts breaking, etc). I was going to purchase one off ebay but they sound iffy.
Old Jul 30, 2012 | 01:54 AM
Ceej's Avatar
I used the bolts that came with the badmab header. So far this is the only issue I have had, so I can't say that it's a shitty header
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
