2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
new ZZP downpipe and CEL problems
Old Jul 16, 2012 | 07:01 PM
Monster666's Avatar
Just recently bought a 2009 cobalt LS with a SC installed. Right before he sold the car to me the seller installed a ZZP catless downpipe.
The codes that are popping up are:
P0036
P0054
P0141
P0148
P2440
I know the first three have to do with the Bank 1 sensor 2 o2 sensor. I have had a trifeca tune to get rid of the codes, but no luck.. I had the guy tune my car three different times deleting codes and flashing but these codes refuse to go away. Both o2 sensors on the downpipe are stock bosch sensors.
This has become the biggest headache i have had with the CEL. Can anybody help figure this thing out?
Old Jul 17, 2012 | 03:18 AM
Ceej's Avatar
You have no cats, so your o2 sensor is reading the wrong voltage. You either need a cat welded on or you need an o2 simulator so the computer is reading it "correctly"
You can clear it and tune it all you want, as soon as it reads it again the codes will pop.
And since you're supercharged I would fix this ASAP because you're just dumping fuel
Old Jul 17, 2012 | 03:28 AM
LtDanBoostdG5GT's Avatar
2 solutions.
a) retune and delete the sensors
b) cat
Posted from Cobaltss.net App for Android
Old Jul 17, 2012 | 03:49 AM
Ceej's Avatar
Wouldn't deleting the sensor not do you any good though
Old Jul 17, 2012 | 11:04 AM
Monster666's Avatar
I just ordered a o2 simulator from tougefactory.com. I'm ready for this to be over with, ill keep you guys posted.
Old Jul 17, 2012 | 11:27 AM
Ceej's Avatar
Let me know if it works I still haven't bought one lol
Old Jul 17, 2012 | 11:57 AM
Cobalt08LS's Avatar
the car isnt tuned already for a catless downpipe?
or did previous owner put it on AFTER he tuned. because if previous owner installed the catless dp AFTER he was tuned for SC than id just get a tune for the downpipe to encorprate everything better.
Old Jul 17, 2012 | 01:16 PM
^^ Yes
Old Jul 17, 2012 | 01:18 PM
Cobalt08LS's Avatar
get your tune updated for the downpipe
Old Jul 18, 2012 | 10:12 AM
Monster666's Avatar
I'll contact the tuner and have him do that as well ^^
Old Jul 18, 2012 | 10:19 AM
aikidoshadow's Avatar
You also might need to check the oxy sensor on the exhuast manifold your last two codes are regarding fuel pressure and the secondary air system.
Old Jul 18, 2012 | 05:48 PM
raymoore1982's Avatar
Most those codes are for downpipe. Don't use bosch sensors the ones I got from GM directly were not bosch. Get your sensors figured out and use a defouler,worked for me! If its 2.2 supercharged more than likely secondary air injection is not hooked up!
This is what I found for P2440
http://www.fixya.com/cars/t9547804-c...411_p2440_mean
Old Jul 19, 2012 | 04:23 PM
Monster666's Avatar
I installed the o2 simulator today. Tomorrow ill check out the oxy sensor as well as the SAI system. My car 's fuel air ratio is going back and forth from 18 all the way to 11.8 during idle after installing the 02 simulator and resetting the CEL. Before it was approx 14.7 afr
Old Aug 25, 2012 | 09:53 AM
Monster666's Avatar
Problem solved. Had a wideband installed in the header and connected the rear o2 electrical connection to the front o2 sensor electrical connection, leaving the rear o2 electrical unplugged, thinkin the rear o2 delete tune would resolve it. I uninstalled the wideband and installed two denso sensors (with the rear o2 sensor delete tune) and no CEL's as of 100 miles so far
Old Aug 25, 2012 | 11:42 AM
Ceej's Avatar
Did you use the o2 simulator?
Old Sep 27, 2012 | 01:34 PM
Monster666's Avatar
No o2 simulator needed
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
