2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
nhanson's S/C build
Old 02-14-2012, 08:14 AM
  #76
jbenso4's Avatar
i wish i did the dual pass immediately.
Old 02-15-2012, 10:23 PM
  #77
nhanson's Avatar
Wideband and pillar installed. Also ordered 60lb injectors and Interceptor.
Old 02-15-2012, 10:41 PM
  #78
klutch814's Avatar
wideband easy to install?
Old 02-15-2012, 10:46 PM
  #79
nhanson's Avatar
Yea it was. I just took out my rear O2 and put the sensor there (now i have to have a code deleted).
I used a add-a-circuit for power.
Everything comes with connectors on them and there already in a cable with plugs.
Old 02-15-2012, 10:49 PM
  #80
klutch814's Avatar
alright i got the glowshift one itl be here.. i wanna install but i wont have the dp till aapril on build day.. so you can unplug and plug this in and itl be all good? they told me unplugged the gauge will flash lol
Old 02-15-2012, 10:51 PM
  #81
nhanson's Avatar
What you mean unplug it?
Old 02-15-2012, 11:51 PM
  #82
heathkidder's Avatar
So where did u put ur rear o2 sensor then didnt ur dp come with 2 o2 bungs
Old 02-15-2012, 11:57 PM
  #83
royce777's Avatar
He just removed it. The newer 2.2ls have a sensor on the header and two sensors on the downpipe. He just rid of the rear one and is gonna delete the code when he tunes.
Old 02-15-2012, 11:59 PM
  #84
Im an 08 would i have one on header and two on dp? I thought there was only one on dp also
Old 02-16-2012, 12:04 AM
  #85
royce777's Avatar
im not sure. your the l61 right? just crawl under and take a look. the older 2.2s i believe just have one on the dp. (i may be wrong)
Old 02-16-2012, 12:07 AM
  #86
Well im not thst old but thing i only have one but sum reason my dp came with 3 lol so i need to plug a hole
Old 02-16-2012, 12:11 AM
  #87
royce777's Avatar
are you going to be running a wide band? maybe you have 2 on your dp. if you run a wide band and have 2 sensors on dp then youll be golden if not its easy to plug a hole.. not sure someone on here will answer your question
Old 02-16-2012, 12:13 AM
  #88
Yea wideband
Old 02-16-2012, 07:55 AM
  #89
nhanson's Avatar
i have the front sensor and a rear sensor. Took the rear one out.
You have 3 bungs. 1 for front, 1 for rear, and 1 for wideband
Old 02-16-2012, 11:53 PM
  #90
klutch814's Avatar
mine came today.. gonna look this weekend .. if not ill run it to the engine bay and connect everything except sensor
Old 02-16-2012, 11:57 PM
  #91
nhanson's Avatar
Nothing bad happens when you take and unplug your rear O2. You just get a CEL
Old 02-17-2012, 12:00 AM
  #92
klutch814's Avatar
its been on all summer so were good lol.. i just dont know if mine has the 2 or one
Old 02-17-2012, 12:06 AM
  #93
nhanson's Avatar
Oh and prepare to put some muscle into getting that O2 off. Otherwise presoak in a penetrating oil/fluid
Old 02-17-2012, 12:19 AM
  #94
zerosk8ter83's Avatar
take the donwpipe off and then try to take it off.Its easier
Old 02-17-2012, 03:19 PM
  #95
nhanson's Avatar
Its not bad with it just on jack stands. Gotta have some muscle
Old 02-22-2012, 05:23 PM
  #96
nhanson's Avatar
Smoothflow 2.9" pulley came today. Awesome quality
Old 03-05-2012, 01:18 PM
  #97
09LAP's Avatar
S/c ftw!!!!
Old 03-25-2012, 09:58 PM
  #98
nhanson's Avatar
Pulley swapped on and s/c sent to euthanasia for porting!
This car will be eating corn once the install happens
Old 04-18-2012, 10:49 PM
  #99
nhanson's Avatar
All parts are bought and will be installing next weekend!!
That blower in the pic above is now Euthanasia ported
Old 04-22-2012, 01:56 PM
  #100
nhanson's Avatar
I will be starting out on 93 then dyno to see where my power is at...but how many people will think i can survive without popping with a 2.9" ported M62 and E85?
Quick Reply: nhanson's S/C build
