2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Nos
Old Oct 30, 2010 | 01:39 PM
dpy31484's Avatar
Nos
I plan on supercharging my 09 in the spring. The mods i plan on having is 2.9 pulley 42# injectors and option b but i'm wondering would it be safe to run a zex safe shot nitrous system on a stock 2.2? Thanks
Old Oct 30, 2010 | 01:41 PM
05Slowline's Avatar
in4thenosflame
Old Oct 30, 2010 | 01:53 PM
iboost's Avatar
Originally Posted by 05Slowline
in4thenosflame
^this...
Zen and NOS are two different companies...
Old Oct 30, 2010 | 02:01 PM
Nighthawk243's Avatar
"NOS" has become a genericized trademark of sorts. Its like Tylenol and Kleenex.
List of generic and genericized trademarks - Wikipedia, the free encyclopedia
See how many things on that list you've been calling by some brand name all along.
Anyways, as far as the OP goes, when it comes to the 2.2, you have to keep your HP at a safe level if you're not upgrading the rods. As long as you keep your total crank HP under 250, you should be safe.
That being said, a shot of nitrous could possibly get you in trouble quickly with a 2.9
dpy31484's Avatar
I mostly put Nos as the title to get peoples attention
Old Oct 30, 2010 | 02:03 PM
dpy31484's Avatar
Thanks nighthawk
Old Oct 30, 2010 | 06:31 PM
mmcgee123's Avatar
To much cylinder pressure for stock 2.2 rods n bearings but go for it holes in blocks or spun bearings are fun
Old Oct 30, 2010 | 10:53 PM
dpy31484's Avatar
As far as the block it self goes i hear it can handle quite a bit..i know i have to worry about the rods but the zex safe shot nitrous system says it adds 15-35hp or you can buy the upgraded kit to add 55-175 shot which i know would be way to much. So pretty much adding the extra 15-35 hp on top of what i gain from installing the supercharger it would be to much for the motor to handle?
Old Oct 31, 2010 | 03:05 AM
The 2.2's block isn't the issue, its everything else. The stock block has been able to withstand 1000HP from GM performance's builds, but they had to replace just about everything else in the process.
I'd say go ahead and do the supercharger setup and see where you're at on power (Through a dyno) and re-evaluate from there.
dennis69
Oct 20, 2015 04:49 PM
TylerJHowell
Sep 21, 2015 06:47 PM
slacker
Mar 5, 2007 09:16 PM
hondaeater
Jul 9, 2006 06:42 PM
knatsabooh
Jun 8, 2006 09:08 PM
