Question
if this is a cat back, you would look on the end of your DP and see, if this is an "axel back" you should look on your cat and see how many bolts it has.
3 flange looks like a triangle:
2 flange looks like a line:
2.2L exhaust
all of the 2.2L exhausts have a 2 bolt setup
_______
(0 (_) 0) <-one bolt, exhaust pipe, then another bolt side-by-side
the 2.4L exhausts have a 3 bolt setup
_______
---/ 0 \
--(0 (_) 0) <-one bolt on top, exhaust thru center, then two bolts on bottom
*hope that helps*
_______
_______
---/ 0 \
*hope that helps*
Iceberg
Sep 29, 2015 12:33 PM
