2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Radiator Hose ID?
Old Mar 30, 2012 | 01:56 PM
2009CobaltLT's Avatar
Radiator Hose ID?
I was wondering if anyone happens to know the inner diameter of the radiator hose on our cars? I have searched around a bit, but each thread on this topic seems to be a dead end. Looking to add a water temp adapter and need to know the size.
For those of you that are going to say "you know the DIC has the water temp", thanks in advance but I already know that.
I'd appreciate any info on this. I just don't want to rip my radiator hose off and lose coolant/add air to my lines just to measure when I am going to have to put it back on and take it off again later on.
Old Mar 31, 2012 | 02:00 AM
Validater's Avatar
Well the hose is at max a 1/4 inch thick, so measure the outer dimension, and subtract 1/2 an inch. That should work. And being that you'd have to clamp it on, there should be no problems.
If I'm correctly thinking of what your are planning on doing. Which I assume it is cut the hose in half and add in a sleeve so you can thread in a sensor.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
