speedometer question
Yes 07+ will work but not 06 or below well for me I have an 09 SS/TC gauge cluster I did a swap on my 08 2.4L and everything works just fine. It's one of the easiest installs I've done yet. Everything will balance out once you do the swap, mileage, temp, RPM and speed will match.
Yes depending on what year cluster it is, mine is an 08 2.4L and has the tire sensor pressure light, if you get an 07 or lower you'll hear the sound but won't see the light, my advice get an SS/SC or TC cluster gauge 08 or higher if your running on tire sensor pressure.
Iceberg
Sep 29, 2015 12:33 PM
