Turbo Vs Supercharger/Procharger
I hear day to day differences and how ones better then the other at the local shop, i hear that turbos are so delicate and need fine tuning all the time. I also here Superchargers are easy installation and produce alot less horse power..
You guys give me the specs..
whats the best?
whats the best?
ok super cost less and is easier to install has low rpm power mild gains up to 220 on stock 2.2, turbo cost more and is alittle more difficult to install has high rpm power with turbo lag but turbo lag can be eliminated of tuned well and can produse alot more power 270 on stock 2.2, my opinion sdont bitch and complain if u think im wrong
and super u get the whine and turbo i get the psssshhh lol i would go with the turbo
It depends on what you're looking for.
If you're just wanting to up the power of the 2.2 without needing to upgrade the internals (You're fine with a mild power increase), then the supercharger is probably one of your better options. It is cheaper to piece together and doesn't have enough potential to blow your engine since the boost is limited. It is also more reliable.
If you're planning on doing a rebuild of the engine to strengthen the internal components and you want huge power, the turbocharger is the better choice. If you have the 2.4L LE5 engine (SS N/A), I'd go turbo since the components in this engine are more durable than the 2.2L L61.
I wouldn't bother with a procharger on a 4 cyl engine. It has been done on an Ion that I know of, but generally prochargers are best utilized on a V8.
Hey man maybe I can help a lil bit. Well I'm asked ppl da same question supercharger or turbo on my cobalt. I have an auto tranny so I'm goin 2 get a zzp bolt on supercharger and my reasons r that if u get a supercharger on an auto tranny is works better than a turbo because if u get a turbo on an auto tranny ur gonna get a lot of boost lag and another reason I'm gettin a supercharger is that u dnt need 2 upgrade ur pistons,camshafts and ect. Wit turbo ull need 2 spend a lot of money b4 u can turbo it cause if u dnt ull blow ur engine right away. So finally I say if u have an auto tranny go wit supercharger its cheaper and better but if u have a standard cobalt and have money 2 spend go wit turbo.
Hahaha! well ive already decided im going to go with a garret turbo charger and upgrade my internals slowly. Ill have it tuned when i put it on and i wont run n2o or anything so im not worried about send a rod through my ******* hood :P Im doing little by little.. What are some of the things i need to upgrade right away?
Maybe he means buy them slowly and let them pile up til he has them all? If he's planning it the way its worded out, that is a horrid idea lol
Rude but so true. that post had the logic of a kindergardener. i mean really? turbo means blown up instantly? news to me someone go tell my 50trim turbo stock block 2.2 motor that its supposed to blow up not run and have the **** beat out of it for 30k miles.wtf?
Not that Garrett isn't a good company or anything, what has you set on them? Second of all, if you need to ask all these questions about turbo/super setups and quite obviously have no knowledge on this at all, you really shouldn't be planning a build at this point. You need to do some research and bone up on ur knowledge. And I mean months of research from all sources, not reading threads on here and thinkin you have it all figured out in a day or even a week. I'm not trying to be a dick, but ask any of the other gear heads on this site or that you know personally and I'll bet they agree with me. If you don't understand any of this forced induction stuff, I can almost guarantee you'll blow ur engine within a week.
Quote:
Are you ******* retarded?
