08 Sport 2.4L Owners
Old Jul 16, 2008 | 10:09 PM
Red07SSNA's Avatar
Any Sport owners want to try installing the 06-07 SS 2.4L one-piece intake to see if it fits and works. We need someone to buy one and try it out. The throttle bodies are different part numbers too, so need to find out if the 08 TB fits the 06/07 SS 2.4L intake too. The 08 2.4L has a smaller 2-piece intake similar to the 2.2.
Any Sport owners willing to take a stab at this and let CSS.net users know the outcome?
http://www.crateenginedepot.com/stor...P1817C137.aspx
Old Jul 16, 2008 | 10:44 PM
chevy cobalt 08's Avatar
I'll take a free one and test it for ya! lol j/k I really don't have the money for anything right now. I really need to start saving up, I'm spending too much on the balt.
Old Jul 16, 2008 | 11:46 PM
Dunkinuts's Avatar
are there any gains that would come from that?
Old Jul 17, 2008 | 10:15 AM
Red07SSNA's Avatar
Theoretically yes, because the ports are larger allowing for some increased air flow. Also it would be interesting to see what the difference in the TB is -- if there is any difference. Can someone with an 08 Sport measure their TB on the inside?
Old Jul 17, 2008 | 10:19 AM
SI FTL's Avatar
hmm.. let me check this out..
isn't that the bolt on 2.4 intake manny for the 2.2?
Old Jul 17, 2008 | 10:22 AM
Red07SSNA's Avatar
Yes it is the 06/07 SS 2.4L manifold. The 08 Sport 2.4 does not use it -- it has a smaller 2-piece glued-together manifold like the 2.2 does. And the TB is a different part number too.
Old Jul 17, 2008 | 10:25 AM
SI FTL's Avatar
Ok, i get you. If it DID fit, I dont think i'd believe in any H/P gains to be honest, Not enough for 250 bucks.. But hey.. Lets start donating money and i'll try it out
It would be fun to give it a shot, I'm just too uncertain..
Old Jul 17, 2008 | 10:34 AM
Red07SSNA's Avatar
Where's your sense of adventure, your drive to get every ounce of power out of your car, your desire to win against all Hondas, your......
Old Jul 17, 2008 | 01:37 PM
Dunkinuts's Avatar
I will measure mine tonight and try to take some pictures.
Old Jul 17, 2008 | 11:26 PM
Red07SSNA's Avatar
Comparison (with thanks to the photographer - he knows who he is....):
https://www.cobaltss.net/gallery/fil.../08_intake.jpg
Old Jul 17, 2008 | 11:39 PM
PenguinPIE's Avatar
the 08 manifold does look smaller...
Old Jul 17, 2008 | 11:45 PM
Red07SSNA's Avatar
I don't know if Chevy just wanted the 1-piece manifold on the SS 2.4L version or if it is because the 08 2-piece manifold is cheaper to produce.
Old Jul 17, 2008 | 11:47 PM
PenguinPIE's Avatar
who knows, maybe the airflow is the same or better
the hp rating does stay the same for 08
Old Jul 17, 2008 | 11:48 PM
08sport's Avatar
I GOT SCEWED OVER this is bs how much would it be for a older mani??
Old Jul 17, 2008 | 11:50 PM
Red07SSNA's Avatar
Call CED in the morning 1-800-441-5150 and ask them. I bet you'll need the PCV plate too -- but hopefully everything else will be the same.
Old Jul 17, 2008 | 11:53 PM
08sport's Avatar
i'll have to do it monday cause i have to lift tomorow morning then fix my screw up on my b&m shiftplus... damn thing you guys have any estamites at all and will it bring up any CELs?
Old Jul 17, 2008 | 11:57 PM
PenguinPIE's Avatar
not really sure about the CEL, i heard it uses a different throttle body too so it might be tricky to hook that up.
Old Jul 17, 2008 | 11:59 PM
Red07SSNA's Avatar
I think the manifold itself will run $100+ -- the 2.2 guys can use the SS 2.4L manifold without CELs (CED sells their kit so that the 2.2 owners can continue to use their TB and the brake boost hose is different on 2.2s). You won't need the kit, but as I posted before you may need the PCV plate -- if the 08 manifold has a drilled PCV hole like the 2.2 manifold does.
08sport's Avatar
what about power gains too?? i wouldn't expect much what would ya thing?
Old Jul 18, 2008 | 12:04 AM
Red07SSNA's Avatar
If it gains the same as the 2.2 engines, anywhere from 5 to 21 HP depending on whos dyno you look at. Chances are it will increase top end the most -- but not low end power.
PenguinPIE's Avatar
hmm i think you'll get better gains spending the same money else where like header and stuff ....assuming yours is already better than the 2.2 intake manifold
Old Jul 18, 2008 | 12:05 AM
Red07SSNA's Avatar
This isn't a stand-alone item, but it will compliment all other add-ons.
Old Jul 18, 2008 | 12:42 AM
PenguinPIE's Avatar
that's true....but what i meant was getting the mod as a stand alone, other mods might make a bigger difference for the price
Old Jul 18, 2008 | 01:28 AM
SI FTL's Avatar
PenguinPIE 08's have 173.. the previous years have 171.. get it right
Old Jul 18, 2008 | 01:42 AM
08sport's Avatar
how?? especially if our intakes are smaller?
