2.4 dyno results after mods and ecu
Old Mar 8, 2006 | 06:53 PM
  #51
jerryg's Avatar
i was at the doctors since last night ill have it in by tonight
Old Mar 8, 2006 | 07:43 PM
  #52
BooSSted's Avatar
Ummm, Sorry but I don't believe it. Either those are flywheel numbers as stated above or the dyno was ******ed. Don't get cocky and think your going to beat an SS/SC, your reaching for the stars when your still in the clouds!
Old Mar 8, 2006 | 07:49 PM
  #53
c7015's Avatar
for the overdose of whatever you were on when you made this thread ...
  #54
WSFrazier's Avatar
Little defensive aren't we?
lol j/k
Old Mar 8, 2006 | 07:59 PM
  #55
BooSSted's Avatar
Lol, no not really, just honest!!
Old Mar 8, 2006 | 08:06 PM
  #56
cashstacker's Avatar
Lol funny but most likely true.
Old Mar 8, 2006 | 08:34 PM
  #57
PpAzZ1101's Avatar
I'm not sure I believe it either...
But I love how all the SS/SC owners get defensive and angry.
Old Mar 8, 2006 | 08:35 PM
  #58
plyboy-illest's Avatar
pretty impressive #'s
Old Mar 8, 2006 | 09:24 PM
  #59
celicacobalt's Avatar
so whats up with the dyno sheets
Old Mar 8, 2006 | 09:30 PM
  #60
WSFrazier's Avatar
He's photoshopping them now.
Old Mar 8, 2006 | 10:00 PM
  #61
Chevypowered's Avatar
........getting less believable
Old Mar 8, 2006 | 10:10 PM
  #62
I now call BS
Old Mar 8, 2006 | 10:43 PM
  #63
GTPprix's Avatar
BTW for the record, this is what a REAL tuned 2.4L SS Dyno Sheet looks like..
Note the low end and top end gains and the area under the curve This thing really flies! hehe
Old Mar 9, 2006 | 12:26 AM
  #64
That looks like the highest hp got out of was 160. Where did this kid get his 220 from?
Old Mar 9, 2006 | 12:32 AM
  #65
campo165's Avatar
do you guys even know what torque is really? you DO realize its NOTHING, right? its just where the engine produces the power to calculate the hp....for instance acuras and whatever have no torque BECAUSE they run up to 8000 rpm for make power...if you look at the physics equation you see this is because once you pass about...5250 rpm's your torque will decrease as your hp inscreases...thats because the equation starts to reverse...hp is rpm's (somethin somethin) divided by torque...torques ONLY PURPOSE is to measure HP output...its quite simple, actually. by having 208 lbs. of torque...that means at around the 5200 range he is producing a good amount of hp...i know that post makes no sense, just google the equation to see what i am talking about.
Old Mar 9, 2006 | 12:57 AM
  #66
stic5's Avatar
Torque definitely IS something. Race an RSX-S or Civic Si and you'll see what a car with no torque does... lose.
Old Mar 9, 2006 | 01:03 AM
  #67
campo165's Avatar
what a stupid response...go learn something about cars and engines. go race a mustang GT you dip...302 ft/lbs torque...know why? BECAUSE IT PRODUCES 260 HP below 5250 RPM...or most of its power anyways...prolly around 230-240 hp @ about 5000 rpm...fool. all torque indicates is where you produce the power at in the RPM range. high torque #'s before 5250 means high hp, youll never see high torque numbers past 5250 unless you are already at a high number...rsx's and such produce their power beyond that number so they have lower torque ratings...
Old Mar 9, 2006 | 01:06 AM
  #68
xonic's Avatar
Originally Posted by Cobalt_Supercharged
That's pretty good. The numbers may vary between dynos though, so your numbers may or may not be that close to and SS/SC. Also if your VVT works like the VTEC it doesn't kick in 'till the upper rpms, where as the SS/SC has full power through out the rpm range. They might get you off the line.
It shouldn't cause the vvt is always working, i'm pretty sure it's always workin in hondas too..the 'kick' is the cam switch which the SS doesn't have.
Campo...you can't call anyone an idiot when you just made a statement saying torque is nothing.
Old Mar 9, 2006 | 01:08 AM
  #69
Cobalt_Supercharged's Avatar
Check out this like for horse power to torque. The equation is hp = (torque * rpm) / 5,252.
http://auto.howstuffworks.com/horsepower2.htm
Last edited by Cobalt_Supercharged; Mar 9, 2006 at 01:13 AM. Reason: Screwed up the equation the first time.
Old Mar 9, 2006 | 01:11 AM
  #70
campo165's Avatar
torque IS nothing...you can have a million torque but you wont go anywhere. its something MANMADE to produce a hp number.
  #71
Ok. I wasn't sure that is why I said if it worked like the VTEC. I really haven't paid that much attention to how GM's VVT system worked. Thank you for the info.
  #72
campo165's Avatar
in other words, its HP that matters, not torque.
Old Mar 9, 2006 | 01:12 AM
  #73
campo165's Avatar
by the way, i love howstuffworks, its sorta addicting
Old Mar 9, 2006 | 01:14 AM
  #74
sorry that was a typo on my part. I changed it it is actually (torque * rpm) / 5,252.
Old Mar 9, 2006 | 01:20 AM
  #75
campo165's Avatar
point being, dont disbelief a torque number cause its a 4-banger. thats a low torque number anywho. (in comparison to other engines in the world) and im flipped here, its hp that doesnt matter raelly, i think. now im confused!
