2.4 dyno results after mods and ecu
Originally Posted by campo165
what a stupid response...go learn something about cars and engines. go race a mustang GT you dip...302 ft/lbs torque...know why? BECAUSE IT PRODUCES 260 HP below 5250 RPM...or most of its power anyways...prolly around 230-240 hp @ about 5000 rpm...fool. all torque indicates is where you produce the power at in the RPM range. high torque #'s before 5250 means high hp, youll never see high torque numbers past 5250 unless you are already at a high number...rsx's and such produce their power beyond that number so they have lower torque ratings...
point being, dont disbelief a torque number cause its a 4-banger. thats a low torque number anywho. (in comparison to other engines in the world) and im flipped here, its hp that doesnt matter raelly, i think. now im confused!
yes yes, torque is needed for towing, but a low torque doesnt necessarily mean low power...a 15,000 rpm bike engine could produce a lot of hp! but almost no torque in comparison. its like...looking from HP's eyes...after 5252 the torque is evening out the equation between rpms and hp...higher rpm, higher hp, lower torque
torque IS nothing...you can have a million torque but you wont go anywhere. its something MANMADE to produce a hp number.
-Rob
Originally Posted by r_fiorda49
-Rob
yea man, you didnt read about that disvoery in school? it shocked the world, discovered in the late 1800's. no doubt torque is needed to pull things, but torque is only good on low based rpms cause of the equation. point being, that cobalt could produce those numbers
in other words, its HP that matters, not torque.
I haven't a clue where you get this stuff
you cannot produce horsepower WITHOUT torque...if you cannot produce torque, you cannot produce HP. HP does NOT produce without torque.
who taught you this junk?
(TQ * rpm)/5252 = HP
(0 * 5000)/5252 = 0
You need to look at that equation and think about it for a minute.
yea they work off each other...thats why its confusing, they are both numbers working off each other. no wonder i got a C in physics
wat was this initally about? oh yea, the torque numbers of the cobalt and how someone couldnt believe them... i think they are believable...if the engine put up good hp numbers before rpm 5,252.
that me!
That number is unmatched in the entire world. Hp is easier to add then torque. Everything is a balance.
I noticed some wrong assumptions as well.
HP AND TORQUE CROSS AT 5252pms. Some were assuming that hp keeps rising. Not if the hp peak is below 5252rpm it doesn't.
Originally Posted by GTPprix
BTW for the record, this is what a REAL tuned 2.4L SS Dyno Sheet looks like..
Note the low end and top end gains and the area under the curve
This thing really flies! hehe
That would be my before and after tune dyno. If you look at the base line tq graph you can see about before 4k thats where the vvt starts kicking in. And yes the thing really flies
I dont see any torque spike at all at 4 K .. VVT should allways be active by definition ... (variable)
Um you need to learn more then just saying what someone else said bud.... High torque before 5200 RPMs doesn't always mean high HP. My dad has a 8.1L V8 that makes 450 Tq around 3000 RPM's, now it only makes 325 Hp how does that fit into your equation. Torque is everything, Hp is just a number to give an idea of power once peak torque has dropped. My turck makes 375 Hp below 3000 RPM's and only 325 Hp, again opposite of how you said its supposed to be.
Just a word, his values might be correct IF he's talking about the back rated flywheel value. The 211HP with a 20% drivetrain loss comes out to 165hp~170hp to the wheels which is very likely with the combination he has. GTPPrix has proven Solstices with intake, muffler, and ECU retune alone can reach near 160hp to the wheels so a CAI, exhaust, header, & ECU could easily create 170HP to the wheel.s
after reading all of this i have one very important question.......................................... .................................................. .................................................. .........
WHO FARTED ?
WHO FARTED ?
