2.4 forged internals discussion
Old Apr 17, 2008 | 04:18 PM
Sw4y1313's Avatar
The only thing i would do to the LE5, if anything, would be to replace the pistons with either custom Diamond Racing or Wiseco at around 9:1 compression ratio. The internals from there can handle the power easily, but running high boost on high compression isnt easy. So to make it easier, just run lower CR pistons.
Old Apr 17, 2008 | 04:26 PM
mike25's Avatar
i think ill leave it at stock compression
Old Apr 17, 2008 | 04:40 PM
Maven's Avatar
Originally Posted by mike25
thanks mave...i got that but i mean give me names of all the best and ill see what i can do...maybe get some new products...who knows
Rods: Carillo, Eagle, Oliver, MGP, Arrow, Compstar, Impo performance, Swanson Precision.
Pistons: Arias , BRC, Diamond, Mahle, Accralite, JE, Wiseco, Ross, Venolia(might not do full custom), Omega
That enough to start with?
Old Apr 17, 2008 | 05:23 PM
mike25's Avatar
yep that ought to do...thanks
Old Apr 17, 2008 | 05:32 PM
bigworm's Avatar
lemme just take a moment to...
ah, thats better...
Old Apr 17, 2008 | 07:22 PM
mike25's Avatar
ah, thats better...
hhmm...care to elaborate?
Old Apr 17, 2008 | 08:13 PM
bigworm's Avatar
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/santa-brought-me-2-4l-finally-98572/
Old Apr 27, 2008 | 11:24 AM
mike25's Avatar
ok i emailed je,wiseco diamond and mahle...now we just have to wait and see what they say...ill have to do rods another day
Old Apr 27, 2008 | 08:07 PM
bigworm's Avatar
or you could just get these: http://www.performanceautowerks.com/...oducts_id=1308
I'd give you part numbers for my wiseco pistons and eagle rods, but i need permission to do so... someone else's hard work went into R&D, sorry..
Old Apr 27, 2008 | 09:32 PM
mike25's Avatar
theyre nice but 1100 just for rods? i emailed those other companies about pistons
Old Apr 28, 2008 | 06:09 PM
  #36
mike25's Avatar
ok heres the emails i received back...
wiseco:
We don't offer anything for that application. We would have to custom make that part. Cost for a custom would be approximately $160 each (includes rings,pin,retaining clips and skirt coating) and it currently takes 4-5 weeks. All information related to your application is required. Attached is our custom order form.
je:
We can custom make these for you. The price is about $165 each with pins, locks, and rings, and it will take about 4 weeks to produce.
not bad i guess
ok i emailed the rod companies and ill have to see what they say
Old Apr 29, 2008 | 05:43 PM
  #37
Maven's Avatar
wiseco:
je:
not bad i guess
Yeah bespoke pistons are no where near as expensive as people would lead you to believe, they are actually very reasonable considering you get exactly what you want, the only problem is you get exactly what you want. So if you mess up on the measurements...your screwed Measure twice, pay once.
Old Apr 30, 2008 | 11:08 AM
  #38
mike25's Avatar
Found some rods at an excellent price!
well i was talking to russel at arrow precision and he told me that 4 forged rods would cost roughly 240GBP which calculates to about 500 USD. Personally i think thats a damn good price. He also told me that if we were to order more the price would go down more
Old Apr 30, 2008 | 11:57 AM
  #39
Shaun927's Avatar
forged rod's and pistons would be great since i plan to sc my car next summer
Old Apr 30, 2008 | 01:21 PM
  #40
Brandon97Z's Avatar
mm forged rods sounds sexy
Old Apr 30, 2008 | 01:44 PM
  #41
mike25's Avatar
if anyones interested check out the thread i made in the advanced section
Old May 1, 2008 | 12:55 PM
  #42
Diamond's Avatar
Whom did you e-mail over here at Diamond? I appologize that you didn't receive a response. If you would like to e-mail me, I would be more than happy to put something together for you.
Old May 1, 2008 | 09:51 PM
  #43
mike25's Avatar
i believe it was rbeaubean@diamondracing ....if you want shoot me a pm or something...i would like to see what you can do
Old Sep 11, 2008 | 09:26 PM
  #44
wollis1's Avatar
subscribed..... i'd be in on a gb or sumthing if we got enuf ppl
Old Sep 15, 2008 | 10:05 PM
  #45
bulls'ss's Avatar
where would it be best to get rings?
Old Sep 15, 2008 | 10:12 PM
  #46
elecblue06's Avatar
hmm forgot about this thread but very interested
Old Sep 15, 2008 | 10:29 PM
  #47
Maven's Avatar
from your piston manufacturers recommendations or your sponsor.
Old Sep 15, 2008 | 11:21 PM
  #48
bulls'ss's Avatar
i plan to get new pistons and rings. just dont no where toy them from. where is a good place to order them?
Old Sep 15, 2008 | 11:31 PM
  #49
elecblue06's Avatar
as this thread says you're more then likely going to have to go custom .. unless you get the 8.8:1 pistons that they sell for the le5 solstice and sky..
a correctly build motor should be able to use stock compression and a good amount of boost.. however 8.8:1 gives you a large saftey net.. that being said you lose a chunk of low end power and if you have a large turbo with alot of lag you'll notice it
Old Sep 16, 2008 | 12:11 AM
  #50
bulls'ss's Avatar
oh. well i plan to run bout 15psi so i wanna do something
