2.4 needs mod suggestions/tips
Old Jun 21, 2008 | 12:36 AM
Zdeuce4's Avatar
I took my 06 2.4 to the 1/4 mile finally tonight. My times basically suck. The first time i ever went to a track it was an 1/8th mile so i improved alot over that experience.
My 4 best times were.
16.29 w/ 2.6 60ft and 87 trap
16.28 w/2.68 60 ft and 88.81 trap
16.24 w/2.5686 60 ft and 87.89 trap
16.13 w 2.51 60 ft and 85.58 trap.
MY RT's are mostly between .5 and .7 yet i still suck. I have k&n intake, CA v1 header, and custom 2.5" piping from the axel back to a borla muffler. and my car is 5 spd. My launches are a bit slow and i dont hop much i just spin like crazy.. What am i doing wrong thats keeping me out of the reasonable range? I have a set of tranny bushings/ xtc catless dp still to install (tomorrow), but i dont see the purpose if i cant even break 15s with wut i have. Im hoping the bushings will eliminate hop from when i actually launch at a higher rpm. Wut are most of u guys doing to get in the mid to low 15s with similar mods? i even took out all the crap in my trunk and lowered the tire pressure. One issue i know i have is shifting to 2nd. I notice that i lose a bit on that shift, wheras others seem to gain ground. I'm gonna dyno it next week to make sure that it's not an issue with the car and that it's all driver. it still only has 9400 miles.
Old Jun 21, 2008 | 12:57 AM
iLLmaTic3s's Avatar
get thos 60 foots down,auto or stick?
Old Jun 21, 2008 | 01:01 AM
Fire_Starter's Avatar
Stick he said, also try launching at 1500 rmps max. Thats what I run as a auto, well 16.3's alot but best was a 16.1 and I have 11k miles.
Old Jun 21, 2008 | 01:08 AM
iLLmaTic3s's Avatar
missed that..my car ran stock 15.7 at the track and my 60' was 2.4....auto btw
Old Jun 21, 2008 | 01:11 AM
Oh and forgot to add im utah, elevation factored in :P
Old Jun 21, 2008 | 01:29 AM
Zdeuce4's Avatar
how the heck do u drop the 60's? i did the 1500k thing.. its just so different in a stick than auto
Old Jun 21, 2008 | 02:02 AM
Chuck's Avatar
Are you popping the clutch?? If so then you may have to ride the clutch alittle and roll on the throttle until you get the clutch all the way out..
Old Jun 21, 2008 | 07:37 AM
DarkSergeant's Avatar
Also.. if spin is your main issue you may want to consider some grippier tires.
Old Jun 21, 2008 | 07:55 AM
steddy2112's Avatar
Yes the stock tires blow ass and *****.
The mounts make it so you can launch at like 2.5k as well...oh and get a tune so you can shift at 7k
Old Jun 21, 2008 | 08:41 AM
Not only do the stock tires grip like ice cubes, they don't last worth a ****. I had mine for 15,000 miles before they started developing bubbles. Dealer said I could try to do a warranty replacement from Pirrelli, but I just bought new ones.
I'd consider you do the same. May want to also move up in width. I think you should be able to fit 225/45 17's without a problem or perhaps 215 45(50?)/17s.
Old Jun 21, 2008 | 09:42 AM
Zdeuce4's Avatar
How much better will tranny mounts make it? can i get those in and be able to launch higher without getting wheel hop or will i still get a bit of it? I also would like a short shifter cuz i was having trouble getting into 2nd. i get to excited, seeing as how on alot of my launches i was outta there at .55 quite a bit, so i would pull the shifter too far down but too far left and wouldn't get in.
As of now im making my focus:
-Tires
-Definitely get my mounts in
-Get dp on
-short shifter
-tune
Old Jun 21, 2008 | 09:48 AM
steddy2112's Avatar
225/45/17s on the stockers.
-Tires
-Get dp on
-short shifter
-tune
Mounts will make vibes thats all. You won't get hop on a hard launch at all...seriously get a tune mainly for the higher redline...
Old Jun 21, 2008 | 10:00 AM
fbaero10's Avatar
my fastest so far was 15.2 @ two different tracks completely different elevations both with 2.1 60' just practice on your lunch dude.. i have yet to his the tracks this year. and have plenty more mods 14s will happen in my na 2.4 lol
Old Jun 21, 2008 | 10:11 AM
Zdeuce4's Avatar
i need to get rid of the wheelhop mainly.. so i can launch higher. im supposed to get tuned next month, It wont be of any use tho if im hopping off the line still.
Old Jun 21, 2008 | 10:22 AM
steddy2112's Avatar
Put your mounts and get good tires.
No more hop
Old Jun 21, 2008 | 12:24 PM
Zdeuce4's Avatar
No more hop
14s here i come...
Old Jun 21, 2008 | 12:26 PM
chevy cobalt 08's Avatar
I reved to 4k and got slight wheel spin but no wheel hop and ran about 16.7ish maybe more maybe less and I'm stock with just a gmpp intake and had some trunk weight and slight elevation plus i'm a sedan. I thought the higher you rev the better your launch? 1500 sounds like too little thats like what i do to get going normally and its got like no launch power at 1500 cause i tried launching at that and it fucked me up with that taurus sho race.
Old Jun 21, 2008 | 12:31 PM
Zdeuce4's Avatar
now that i think about it. i think my car was hitting 16 instead of 15 because my rt was so low. i was going over the line kinda slow clossing the clock to start.
Old Jun 21, 2008 | 12:39 PM
steddy2112's Avatar
Originally Posted by Chevy Cobalt 08
I reved to 4k and got slight wheel spin but no wheel hop and ran 16.7 and I'm stock with just a gmpp intake and had some trunk weight and slight elevation plus i'm a sedan. I thought the higher you rev the better your launch? 1500 sounds like too little thats like what i do to get going and its got like no launch power at 1500 cause i tried launching at that and it fucked me up with that taurus sho race.
Fail.
2.5k with mounts...1.8k without.
16.7 is terrible.
Don't get all emo on me, I just told you how to be faster...
RT has nothing to do with 1/4 time!
Jesus everyone has gone stupid all at once all over this forum!
Last edited by steddy2112; Jun 21, 2008 at 12:39 PM. Reason: Automerged Doublepost
Old Jun 21, 2008 | 12:41 PM
no i know that's terrible thats cause i wasn't on a track and i had trunk weight (tool box, spare wheel, other stuff) and part of the street i was driving on became slightly elevated. so your saying the best launch for non mounts is 1800?? hmm.. ok (only asking if i take it to raceway park thats the only racing I do) i was just curious to see my times on non track
Old Jun 21, 2008 | 12:57 PM
iLLmaTic3s's Avatar
rt doesnt mean crap as steddy already said..its when ur car moves across the line the time starts...def ur 60' down and u shud b in the low 15's wit ur mods
Old Jun 21, 2008 | 01:41 PM
Zdeuce4's Avatar
Fail.
16.7 is terrible.
crap im just hungry..
that's wut i was tryna say.. dumb me.. i was going over the line slow and then hitting it is wut i was trying to say.
is it just me or did CC08's first time say 15.2? earlier...
Old Jun 21, 2008 | 01:48 PM
SI FTL's Avatar
[QUOTE=steddy2112;2496744]225/45/17s on the stockers.
QUOTE]
Can i run a 225/50/ on the stock 17's? I'm looking for daily driver but don't want to gain more wheel well space after the pro-kit I'm lookin at the BFG Sport series
Didn't mean to thread-jack!
Old Jun 21, 2008 | 02:17 PM
BigEMU1's Avatar
Don't just dump the clutch and hammer the gas, you'll never hook up and maximize your power in 1st. Rev it to around 2 grand, dump it, let your tires sink in to the sudden burst of speed from the launch, THEN go WOT. If you're squeeling you're not putting power down, plain and simple.
I usually dump it around 2k, max 2.5k, then hold the pedal at about half or 3/4 throttle until it completely hooks from the launch, then go wide open. You're already going to be spinning off the launch so why throw more power at it? The launch RPMs are not critical in comparison to what you do to control your tires from that initial jump you give it. More is not always better. Then again you want to maximize your power so ideally you'd want to give it just enough pedal to hook up and be boarderline/slightly breaking lose from the throttle you're giving it.
The best advice I can give you is listen to your tires.
Old Jun 21, 2008 | 02:25 PM
steddy2112's Avatar
[QUOTE=XtortedCobalt;2497476]
QUOTE]
There will be space...they will have one fuckfest of a time trying to get your tires on.
And Z, I wasn't referring to you man, right before lunch there was all kinds of stupid roaming amuck.
A tune with the 7k redline will help at the strip big time.
Also, practice launching without bogging the **** out of your car...you really have to roll onto the throttle...
