2.4 supercharger?
Originally Posted by jaslowyota
i wish someone could come out with an nice tune or stand alone because it seems like the lsj setup would fit so easily on our motors
The only thing I'd really be worried about is since the 2.7 pulley is at the edge of the M62's efficiency, it will be pushing hot air, which will make tuning to avoid detonation more difficult. Using the SS/SC's aftercooler, and preferably a bigger heat exchanger and reservoir, will probably be a must.
Head porting and cams would probably bring even further gains.
I'm waiting for Hahn Racecraft to come out with the Turbo Kit. I saw a review for it in a mag. Said about 244 whp. The supercharger mentioned above only adds 60! But hahn isnt even done tweaking it yet.
Our vvt is kind of a problem. Not to get off the subject but my car mas been at K&N also at AEM and for alot longer than normal to get the intake to work properly, with the vvt, it just takes a bit more work to get it perfect. I know my car is at K&N as I speak and they needed it a few more days to get this out and to give us gains they would like to put out on the market
Originally Posted by CobaltSonOfS.A.M.
All f/i applications can bennifit from a lower compression ratio, lower c/r = more boost, more boost= more power. Point blank!
The high CR keeps the engine very responsive I beleive and helps combat the lag on a turbo
yes it does, but with advances in turbo technology (ie the dual-scroll turbo in the Solstice GXP, and the veriable geometry turbo's in the 911 turbo) They can nearly eliminate turbo-lag, all higher comperssion really does is hinders our progress when we are trying to make our cars faster for the least amount of time and money. Changing pistons for some low compression ones isn't cheep labor.
Originally Posted by avro206
I am not going to really argue that----but virtually every modern production F/I induction engine runs way more compression then they did in the past. Powerful computers and sensors to dected detonation and direct injection make this possible.
actually, more compression with the same boost will make more power. That's a fact. It is not as safe to run high compression, but im just letting you know for future reference more compression, more power. ALWAYS.
z28addiction
Sep 28, 2015 12:03 AM
