2.4l coolant temp problem
Old Nov 21, 2008 | 10:39 PM
slowswap's Avatar
My buddies car always throws a check engine light when his temp displays ---. His car won't throw heat inside the cabin either.
Does your car still throw good heat when its above 100 degrees?
Old Nov 22, 2008 | 07:09 PM
BlilBT's Avatar
Originally Posted by Cloudio
alright guys ....iam gonna get it checked out .....thank you ... ill keep you guys posted
I told you what it is >>> I've had this problem >>>>> But what ever!
How Many Miles do you have? & when was the last time you changed your filter ? & what octane do you run all the time? All these things can make what is happening happen!
Old Nov 22, 2008 | 07:23 PM
slowswap's Avatar
Everyone has had this problem with different solutions. All he can do is try them all.
Old Nov 22, 2008 | 07:32 PM
BlilBT's Avatar
I have the Books & Had the car working on 3 years this has happened twice to my wifes car & always been the same problem, even the book says the same thing.
Like stated be4 if was the stat it wouldn't go blank, if its a short it will blow the fuse & Nothing not even lines would show... but what do I know!
Old Nov 22, 2008 | 07:37 PM
slowswap's Avatar
Stuff you did is completely unrelated to the --- symptom. It's pure concidence that what you did made it go away.
In most cases its sparetic when it happens. If you can't get heat into the cabin after a long time of driving, it's the thermostat. The fans will always come on when you have this problem to because the car can't tell if its overheating or not.
Old Nov 22, 2008 | 07:44 PM
BlilBT's Avatar
Dude the car shuts all this things down to protect itself trust me I Know & it's no concidence as you call it involved! Like I stated what ever do what you want... What do I Know I just have 1 of the most Modded balts on this site!
Old Nov 22, 2008 | 07:57 PM
slowswap's Avatar
So you're saying the cars temperature will read --- when the air filter is dirty or the wrong gas is used. You have to be kidding me. This is a joke right?
Old Nov 22, 2008 | 08:18 PM
BlilBT's Avatar
Yes it will & it is all tied to emissions which is COOLANT, GAS & AIR Like I said smart ass do what you want. If it works he spends Nothing if it doesn't what did it cost him. The problem with these forums someone comes on with a problem>>> You had said problem, Resolved said problem BY making her switch gas & Cleaning filter after going thru service manual makes said problem go away, it doesn't take rocket science to figure out. You Know what the dealer told me when we took it in>>> Dirty injector, car had 22K & origanl air filter again Emission & IT's NO JOKE! Oh by the way I have all 3 Volumes of the service manual DO YOU, I also Have HP Tuners & was able to read the code it was throwing!
Old Nov 22, 2008 | 08:20 PM
slowswap's Avatar
IT's???? Are you talking about intake air temperatures or something?
Old Nov 22, 2008 | 08:27 PM
BlilBT's Avatar
No I'm talking why he's car is reading---- Because the air or gas is bad & is also tied to the coolant for emissions & it makes the bars go---- another words it's telling 1 of the 3 are having a problem! Oh by the way it can also makes the car run rough & gets worse gas mileage!
  #36
originaladrian's Avatar
i kinda with u... i mean ill listen to anyone... but when something is wrong with my car i throw codes and the CHECK ENGINE LIGHT comes on... not ---
but ill listen to anyone... i guess
Old Nov 22, 2008 | 08:34 PM
  #37
slowswap's Avatar
The check engine light that will usually come on when --- is displayed is as follows.
http://www.obd-codes.com/p0128
Old Nov 22, 2008 | 08:42 PM
  #38
BlilBT's Avatar
Again I will say it 1 last time>> DO what you want your such a smart new comer that can use the computer. I had it happen I have the service manuals & have fixed this problem twice..! He can try what I said it wont cost him a dime & yet your argueing.. Why because you refuse to believe it might work! I don't get it & I'm done with replying to stupid ****! Time to watch the game!
Old Nov 22, 2008 | 08:44 PM
  #39
Cloudio's Avatar
Heater works great however air conditioning doesnt work at all the air doesnt blow cold as long as the coolant temp reads ---
Old Nov 22, 2008 | 08:46 PM
  #40
slowswap's Avatar
My buddy has the same problem. It comes and goes when it wants. It could go months without doing it. Then it could repeat itself for 5 days straight. You can't prove you've fixed the problem when its repeated itself in a short amount of time. I know more how to fix a car and problem solve then I do know how to use a computer.
Old Nov 22, 2008 | 08:50 PM
  #41
Cloudio's Avatar
Always used 91 octane supreme from chevron since the day i bought the balt ......granted my AEM filter hasnt been cleaned in some time ...ill give it a good cleaning tomorrow and let you know the results.....
ya i have the same issue ive thought its been fixed over half dozen times now
has your friend replaced his thermostat??? any results?
Old Nov 22, 2008 | 08:52 PM
  #42
BlilBT's Avatar
Clear the ignition if you have a check engine light & check the sensor while your there! Trust me last year about Oct my wife had this problem & I cleaned the filter. Now last week it did it again about 16k later did the same as before & problem solved! You could have also been getting bad gas, so watch where you buy it!
Old Nov 22, 2008 | 08:58 PM
  #43
slowswap's Avatar
We have plans to replace the thermostat in spring when he can drive his second car on the rode and afford to have this one down.
And I doubt you've fixed the issue if its come back in 16k miles because my friend has had it come back in 20k miles once when he first bought it. He did nothing and it just went away a few restarts later.
Old Nov 22, 2008 | 09:04 PM
  #44
BlilBT's Avatar
Look its called dirt! enough said, oh by the way whats the suggested miles for a filter change depending on conditions!!
Old Jan 13, 2009 | 02:49 PM
  #45
Cloudio's Avatar
so after alot of time down an many different approaches it ended up being just posted early shot thermostat ..soon as it was replaced vehicle runs 100% passes smog no cels
so after alot of time down an many different approaches it ended up being just as posted early shot thermostat ..soon as it was replaced vehicle runs 100% passes smog no cels
Old Jan 13, 2009 | 03:21 PM
  #46
slowswap's Avatar
kthxbye
Old Jan 13, 2009 | 04:09 PM
  #47
BlilBT's Avatar
Thats good, mine was doing the same thing when you posted this & mine was a dirty air filter! Same thing car runs great no cels.. oh & I went with a K & N this time. I let you know if it does it again, but it checks out good so far!
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
