2.4L engine rpm's issue?
Old Mar 31, 2007 | 06:41 PM
TheDriver!'s Avatar
Question 2.4L engine rpm's issue?
Ok I wasn't sure if I should put this in problems etc but its a 2.4Lss so I put it here.. Soo this is what happened..
I went for a cruize in my town here and yes I was speeding (140kmph) on a nice stretch. And anyways I had been off and on the gas before such event mentioned when I started to take her easy and let her come back to earth when I noticed the rpms were'nt coming down as quik as you would think!! Then they would and go up again and I would have to give her some gas to knock em down again..
Just curious if anyone with any model Cobalt has had this problem?? I push my car good sometimes and have never had this issue b4Did I something up??[/B]
Old Mar 31, 2007 | 08:49 PM
eber's Avatar
Even when my car is not in gear and I coast down a hill or move at all for that matter my RPM's rise for some messed up reason
Old Mar 31, 2007 | 10:20 PM
pjk91's Avatar
mine does this regularly, and even at low speeds. its like the throttle is getting stuck or something. i havent had it checked yet.
Old Apr 1, 2007 | 12:14 AM
Halfcent's Avatar
I'm old school
Are you automatic?
Old Apr 1, 2007 | 08:58 PM
pjk91's Avatar
5spd
Old Apr 2, 2007 | 12:29 AM
TheDriver!'s Avatar
ya I'm a 5 spd I think it may be gas cause I put the regular back in (esso regular) and it seems fine now..
Old Apr 2, 2007 | 12:52 AM
TCarter's Avatar
i took mine in awhile ago, for a similar reason, in my 2.4L auto, i could shift into neutral, and itd rev to 2.5k RPM...they said its the TPS was screwy....
Old Apr 2, 2007 | 12:56 AM
MARIN007's Avatar
Did they fix anything?
Old Apr 2, 2007 | 01:05 AM
TCarter's Avatar
No, I didnt feel like them ******* it up.
They always tend to brake something else thats not warrantied each time im in there under a warranty.
I go in for my springs being too squeeky....few days later, my rotors are warped and my brakes are shot because of the uneven surface....they said its because of the way i drive my car.
I just need to wait until my warranty expires, so I can do all the work myself.
Old Apr 3, 2007 | 10:55 AM
xxdarkbladexx's Avatar
IS it suppose to rev higher than that cuz i have that same issue but isn't that just the rev limiter?
RaginChopsuey
Oct 27, 2015 01:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
