2.4L LE5 supercharged
I have a few questions about supercharging a N/A 2.4 SS. To anyone that has done it, is it worth it? Will I have engine problems? My SS has 145k miles on it so I know I risk blowing the engine, but obviously don't want that to happen. How much am I going to end up spending? Thanks in advance.
If you read the threads in the forum you posted in you will find all of your answers.
https://www.cobaltss.net/forums/how-...through-80620/
I say go for it! It's a simple and straight forward swap. And affordable, low mileage LE5s are allover the place.
The parts are cheap, readily available, and if your motor does pop, you have the advantage of getting a new one very cheap.
Man, im prodding at this one.. there has to be a point to when you would drop. i mean, at what point do you have too much air and fuel in a small compressed state. Unless youre implying that it would be unrealistic to go over a certain point of boost on these cars??
If you can explain in the least amount of words, that would be a challenge because im sure it has a long winded explanation...
If ever in a pickle, do you know how to tune at all? Ive got the general concept down. Just never could find anyone in the area...
So, at what point can there be too much air for a cylinder to hold before it is no longer efficient??? Or am i way off track in my questioning?
Higher compression ratios are more efficient by the laws of thermodynamics. Lowering the compression ratio is just going to net you less power. Unless youre going for 700+hp, dont even worry about it.
The general issue is higher compression leads to higher cylinder pressures and more heat which requires extra cooling and higher octane to prevent detonation or per-igntition. So the compression ratio you want to run really depends on what cooling mods, fuel, and how close to the edge you want to run it.
Good explanation!
There has to be posts out there, but for just a quick reference... how much boost is permissible on 93, for an LE5 before detonation or pre-ignition occurs?
Would a dual-pass help with combating this???
Good reference to come back to ill say
That's not how it works. It's not about boost. It's the timing. Higher compression tends to knock on lower octane gas with little timing. When I was on 93 we could only run 10 degrees of timingbefore it would knock. Now on e85 I'm at 23 degrees.
