2.4l tranny fit in 2.2l ls (AUTOMATIC)
Old Jun 12, 2011 | 09:57 PM
protorox's Avatar
im looking to get a beefier tranny for my 2.2l ls automatic, blew my stock tranny. ive heard the 2.4l tranny will fit, is this true?
Old Jun 12, 2011 | 10:04 PM
06blackbalt's Avatar
yes it should fit
Old Jun 12, 2011 | 10:12 PM
Dragonsfire12345's Avatar
its the same transmission
Old Jun 12, 2011 | 10:33 PM
07BoostedG5's Avatar
^x2
Old Jun 13, 2011 | 09:58 AM
protorox's Avatar
Thank you guys so much the beast will be running very shortly then. I'll post vids I'n about a month.
Old Jun 13, 2011 | 12:06 PM
Mindrot's Avatar
The 4T45E transmission is in both the 2.2 and the 2.4
Old Jun 13, 2011 | 01:16 PM
the 2.4 tranny has a different gear ratio thats it
Old Jun 14, 2011 | 05:57 PM
DaBuzzard's Avatar
^^^ The auto's have the same gear ratios and final drive ratio in the 2.2 and 2.4 afaik. Same tranny in a G6 base model has a shorter final drive ratio, other applications have taller ratios.
To the op - you won't gain anything by pulling a tranny out of a 2.4 car, they are the same.
They really can handle some power - 200+ ft/lbs iirc.
If you can get one out of a G6 base model, they have a 3.91:1 final drive as opposed to the 3:63 as used in the Cobalt - little better acceleration but a little worse mileage
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 28, 2015 01:31 PM
