2.4L turbo question
Old Feb 9, 2009 | 02:13 AM
Army_SS's Avatar
2.4L turbo question
I am looking at the 2.4l hahn turbo kit and just had a couple of q's. im fairly new to the turbo **** so,... what kind of exhaust setup are you using, catback and high flow cat etc... what all did you have to purchase other than the actual kit from hahn, and did you install yourself,... or take it to a shop? and info would be greatly appreciated. Josh
Old Feb 11, 2009 | 06:36 PM
celicacobalt's Avatar
im running a corsa 2.5 inch touring catback and a 3 inch zzp downpipe with a high flow 3 inch cat. had it installed and tuned at a local shop but have 60# injectors and 11 psi instead of the way it comes.
Old Feb 12, 2009 | 06:55 AM
Thorin's Avatar
do you get any problem at all since the instalation?
Old Feb 12, 2009 | 07:02 PM
little things i need to work on, would be taken care of if i found a good tuner and some money.
Old Feb 12, 2009 | 07:07 PM
Brandon97Z's Avatar
Let me know where you find it i've been lookin for some myself
Old Feb 13, 2009 | 06:31 AM
DarkSergeant's Avatar
I'm running a GMPP Performance exhaust (2.5) with stock DP & cat.
I believe you should be able to run even a complete stock exhaust fine.
The only problem I've had with with mine is a bit of hesitation and sometimes misfires on cold starts. After the car warms up it's good. I think this has to do with the fuel pressure regulator the Hahn kit uses. It's also been greatly reduced since changing plugs to LTRZ5A-13 (or something like that) gapped at .026. That came recommended from Hahn.
If I had to do it over again, I would've probably more closely considered buying the Garrett 2.2L kit and having the fuel management dyno tuned.
Only other major problem it's gotten is a ticket from a Trooper a couple of weeks ago .
Edit - One other tip. You'll want to get in there and move any hoses, a/c lines or random pieces of metal out of the way that are remotely touching your i/c piping. Surprisingly a piece of pipe rubbing against a radiator hose constantly can actually wear down the metal and give you a boost leak. I just wrapped all my touch points in some high temp tape as a solution.
Old Feb 14, 2009 | 12:37 AM
I asked hahn a while ago. They didnt get back to me on it. Mine misfire cold but do it alot less or not at all when fully wrmed up. Im gapped at .040 though.
Old Feb 15, 2009 | 05:48 PM
Well, my bogging is completely gone. Here's what I did... FUEL FILTER.
No ****, right? Well, guess what - I hadn't changed it since I bought the car. I was planning to when we did the turbo install (since that was around 30k miles) and I guess we forgot.
Anyhow, that bastard was nasty, rusty fuel came out.
I'd say try that, and the new plugs... and make sure you're running enough pressure. If you haven't set your BFR on a dyno, try it.
EDIT - Yeah, 0.040 is WAY to big. Hahn actually recommended 0.030, my turbo mech here said go to 0.026 since I'm apparently pushing close to 10 psi (vice the intended 8). Same plugs though. They're REX or SRT or something plugs, can't remember, just check NGK's site. If you can't find them, let me know. I ran the stock gap for about the first 500 miles just to try it out, ran like shitty-****.
Old Feb 15, 2009 | 07:16 PM
pjk91's Avatar
you really think .040 is too big? the srt boys run low gaps, and so do boosted hondas. but that doesn't necessarily mean we should too. smaller than stock yeah, .030 no.
Old Feb 15, 2009 | 10:02 PM
A turbo gear Web site that sells Hahn kits for Solstice ... different turbo, but same engine, same PSI:
http://www.turbo-kits.com/solstice_turbo_kits.html
From Aaron @ Hahn, to me. September 08:
Yes we like to see .030”
Let me know what exactly you are seeing once this is complete.
Also you have 93 octane fuel in the car correct?
For the fastest, most effective support, always use the "reply" function to keep any previous messages attached.
Aaron Gilberg
Tech Dept.
Hahn RaceCraft, Inc.
205 Beaver Street
Yorkville, IL 60560
From Aaron, @ Hahn, to me. June 08:
Tech at Hahn RaceCraft to me
show details 6/25/08 Reply
We recommend NGK V Power plugs Stock No. 4306 Part number LZTR5A-13 gapped to .030"
Aaron Gilberg
Tech Dept.
205 Beaver Street
Yorkville, IL 60560
630.553.1696
tech@turbosystem.com
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
