2.7 pulley... how much boost?
Old Jul 25, 2010 | 12:44 PM
senior_brown's Avatar
just curious as to how much boost. preferably in total kpa reading that your map sensor is reading up to stock redline (6850rpm)
im reading approx 225kpa, which is about 15 psi.. is that right??
Old Jul 25, 2010 | 03:30 PM
mtbrent's Avatar
sounds correct to me. Ultimately it will depend on your setup and how well your motor flows, but the 2.4 will see less boost per pulley size when compared to the 2.0 or 2.2 always. 3.0 pulley saw 9-11psi depending on atm conditions on mine(and many others), so .3" less pulley I would expect 12-14 roughly.
Old Jul 25, 2010 | 04:29 PM
stock pulley gave me 7psi, 2,9" pulley gave me 11 psi, so i guess ur right...
anyone else got any inputs?
Old Jul 25, 2010 | 04:49 PM
Armyguy151's Avatar
I had the cobalt addiction gm stage 2 upgrade pully 2.79 and was at 17psi...like mtbrent said i guess it's how your setup is and how it flows
Old Jul 25, 2010 | 05:12 PM
17 psi?? wowww
u have a stock intake and exhaust system or something?
i mean im fully bolted on everything and am surprised im hitting 15psi
Old Jul 25, 2010 | 05:30 PM
Armyguy151's Avatar
at the time I had fujita 3'' intake,header,catless downpipe and full exhaust. I dynoed 258whp and 250fpt...no porting of anything
Old Jul 25, 2010 | 07:14 PM
mtbrent's Avatar
lsj right?
Old Jul 25, 2010 | 07:37 PM
Dayta's Avatar
19psi
Old Jul 25, 2010 | 07:39 PM
06_SIC_SS's Avatar
assuming stock blower..
Old Jul 25, 2010 | 07:43 PM
stoon_cobalt_colby's Avatar
i hit 16.3psi on my 2.9 i got cai,header/dp , muffler :P
Old Jul 30, 2010 | 03:11 PM
SS Flash's Avatar
im at 12lbs with a 2.8 pulley on my 2.4l
Old Jul 30, 2010 | 03:16 PM
ecot3c inside's Avatar
Is it cool if I say...... Just because you have high boost does not mean you won't get your ass raped by another guy pushing 12 psi.
Old Jul 30, 2010 | 03:25 PM
Staged07SS's Avatar
Administrator
Administrator
No one can tell u what a 2.7 pulley should be "boosting" at. There are to many variables that will alter the number (modifications, elevations, location, temperature, etc). You want your boost as low as possible when you pulley down. The lower it is, the more efficient your setup is. Remember boost is a measure of restriction (wow I have to state this a lot), and high boost levels do not mean big power.
Old Jul 30, 2010 | 03:31 PM
coopercharge's Avatar
Agreed
Old Jul 31, 2010 | 10:51 PM
Dragonsfire12345's Avatar
I'm getting 14psi with mine
Old Aug 1, 2010 | 05:13 PM
Armyguy151's Avatar
Originally Posted by mtbrent
lsj right?
Yes LSJ
Old Aug 2, 2010 | 07:19 AM
Staged07SS's Avatar
Administrator
Administrator
Everyone needs to stop comparing their boost levels. It means absolutely nothing, and is irrelevant.
Old Aug 2, 2010 | 07:21 AM
Chevycobaltss3's Avatar
EXACTLY WHAST I SAY, MODES TEMPOS, IATS DRIVER HABITS, TUNE ALL HAVE TO BE CONSIDERED. There is no such thing as a boost level for a pulley. just restrictions.
Old Aug 2, 2010 | 02:51 PM
Armyguy151's Avatar
OMG I'M FREAKING OUT!!!! AAAAAAAHHHHHHH THIS BOOST THAT BOOST EVERYONE CALM THE F*CK DOWN
I wonder how pissed staged07 would be if i put 17psi in my sig with 2.79 pulley ~~~~~~>that's how much boost is from a 2.79 bwaahhahahahahahahaha
Old Aug 2, 2010 | 02:54 PM
Staged07SS's Avatar
Administrator
Administrator
Haha ....
Old Aug 2, 2010 | 02:55 PM
Armyguy151's Avatar
Haha ....
I love it
Old Aug 2, 2010 | 03:00 PM
Lol!!!
mtbrent's Avatar
It may be irrelevant to you, because you are so smart, but maybe the OP thinks his cat is clogged, and he's seeing too high of readings. Or maybe he just wants to see if his 2.7 on his LE5 is in the correct range, and yes, there is a RANGE for each motor that should be acceptable per pulley. If he came in here stating 22psi on a 2.7/LE5 we would quickly all jump in and say that's too high and there is a restriction somewhere. Would you say his numbers are irrelevant then?! You are correct with all your facts, but maybe some people just want to know what others with an M62 on their LE5 see for boost...
Old Aug 2, 2010 | 03:09 PM
There really is no based boost for pulley because i can clogg my cat up on a stock pulley and i bet you ill at least getup to 18 lbs of boost lol, lets do it ricers ha ha ha ha ha lol. j/k. but yeah bro if you want more power go to all mods you can get tune, and a 2.8 pulley or in my case built motor so i went to a 2.6.
if he has a m62, intake and supporting mods i say he will see around 15-18 lbs just saying...
Last edited by Chevycobaltss3; Aug 2, 2010 at 03:09 PM. Reason: Automerged Doublepost
Old Aug 7, 2010 | 01:27 PM
boostedsport's Avatar
i'm spiking around 16 with a 3.1 on a tvs more then i will ever need
269 whp and 218 lbs of torq
13.6 i need some motor mounts and learn how launch and not to peel out in 1st and 2nd
