2007 LE5 vs. 2008 LE5
Old Jul 22, 2009 | 09:00 PM
blackss2.0's Avatar
i read somewhere that the 2007 Le5 had around 150WHP while the 2008 had close to 159WHP. just curious if anyone has the answer thanks
Old Jul 22, 2009 | 11:39 PM
avro206's Avatar
I'd suggest that's not true.
Old Jul 23, 2009 | 09:07 AM
brickerenator's Avatar
difference is 2 brake HP
Old Jul 23, 2009 | 11:15 AM
DaBuzzard's Avatar
QFT
171 at the crank for 06 / 07, 173 for 08....at least that's what GM claims.
I expect you could take 10 brand new identical Cobalts (any trim as long as all the same), run them on the dyno, and get a 3-4 hp range in outputs just based on the variations (small as they are) from one car to the next.
Old Jul 25, 2009 | 11:27 AM
pat_07ss's Avatar
Originally Posted by DaBuzzard
QFT
171 was in 06 only
07 and up are 173
nobody dynos at the same numbers... a click of a strap makes you gain WHP
Old Jul 25, 2009 | 01:33 PM
Originally Posted by pat_07ss
171 was in 06 only
07 and up are 173
heh
you're right
weird
I distinctly remember Chevy claiming a 2bhp gain over 07
Old Jul 27, 2009 | 12:28 PM
DaBuzzard's Avatar
171 was in 06 only
07 and up are 173
I stand corrected on the years.
Was more talking brake horsepower than whp though, I am very well aware of how much effect lashing the car (or bike in my case) down tighter has on the numbers produced
Point I was trying to make was that no 2 engines (or transmissions) are exactly identical from the factory - at least not in a < $25k econo box, might be a different story on a > $1m exotic.
Should play with tire pressure on a dyno some day, can make for some "interesting" results
RaginChopsuey
Oct 27, 2015 01:27 PM
agentirons
Oct 16, 2015 02:11 AM
Sep 28, 2015 12:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
