5 sp tranny
get a lighter flywheel..... if it feels long going into the gears, a short shifter would be a good idea too, big help for minimum cost.... prolly the one thing i should have gotten for my old cavalier.....
i dont feel liek diggin up the old thread so ill sum it up real fast, when you shorten the throw, you increase the amount of force that the syncros engage with, specially when you rip through the gears. This abuse to the syncros will cause to wear quicker then a normal shifter.
I've seen people lose syncros 5-6 years range. Its happened to multiple people I know so that why I advise against them. Everyone is free to do as they please I'm just trying to save someone some money.
I received a reply back from TWM...take it for what its worth
Hello Jerry,
Thank you for your inquiry. This is one of the most inaccurate myths
present in the aftermarket industry today. A short shifter is in no way
damaging to the transmission or any related components. It is worth
mentioning, however, that there is a period of time after a shifter is
installed where some care is required in order to become acclimatized
to
the new part.
After a short shifter has been installed the time it takes to shift is
reduced and the timing between your hand and your clutch foot must be
adjusted. Some people install a short shifter and immediately proceed
to
shift as quickly and as hard as possible. We recommend that all of our
customers take several days to become accustomed to the new shifter
before
they try any high-rev shifts or faster shifting. Once the timing for
the
new shifter has been adjusted there shouldn't be any problems shifting
the
car in any circumstances.
I hope this helps. If you would like to purchase the shifter it can be
found here:
http://www.twmperformance.com/shorts...rtshifters.htm
Let me know if I can assist you further.
Kevin
TWM Performance
Hello Jerry,
to
the new part.
to
before
the
the
found here:
Kevin
TWM Performance
All I know is what has happened to my friends cars. Its up to everyone to make their own discsion(sp?) based on the facts that they know.
no, what they are doing is extending the rod length so that the throws between gears are actually shorter. Although shortening the top of the shifter makes the shifter lower the extending of the rod at the bottom is what is actually shortening the throw.
if you just cut the stock shifter down you will not have the same effect.
I plan on going with the lightweight flywheel in the future. right now I have the short throw from TWM and I have to say, applause the TWM. They did very well on instructions and building the part, I love it. It did take time to get used to it though. the first day i had it in, i grinded 2nd and 3rd every now and then, but now its perfect. When done correctly, i have no time between the gears and people outside the car have asked if its an auto.
Iceberg
Sep 29, 2015 12:33 PM
