About Time
Old Nov 4, 2012 | 04:29 PM
  #176
bluebalt07's Avatar
Sc. Done
Old Nov 4, 2012 | 05:06 PM
  #177
nhanson's Avatar
Id turbo the 2.4
Old Nov 4, 2012 | 05:11 PM
  #178
bluebalt07's Avatar
Both. Ohh wait bad idea lol
Old Nov 4, 2012 | 05:57 PM
  #179
chevygirl2006's Avatar
That's what I'm doing.
Old Nov 4, 2012 | 10:33 PM
  #180
06Cobalt2.4's Avatar
So I feel the need to throw this out there.. I replaced my thermostat the same day that I went to HPT, a few hours earlier... I drained my coolant when I disconnected the radiator hose from the thermostat housing.. Anyway to make a long story short.... I had no coolant in my car, and I just put a little less than a gallon in.
Old Nov 5, 2012 | 12:13 AM
  #181
CobaltItaliano's Avatar
could you say this again in a better written way? lol. I'm not following this sentence too well
Old Nov 5, 2012 | 12:48 AM
  #182
I was running my car with no coolant, the day I took it to the drag strip.
Old Nov 5, 2012 | 01:36 AM
  #183
Vander Nars's Avatar
Iv never seen so many excuses before in my life, look u ran good times better then what most aaid u would but ur not gonna pick up another .25 in the 1/4 mile by dusting ur tires off and picking the rocks out of the tread. Stop crying like a girl already.
Old Nov 5, 2012 | 01:45 AM
  #184
defo98's Avatar
Are you saying you still beat on your car at the strip knowing you were running low on coolant I dont understand?
Old Nov 5, 2012 | 10:56 AM
  #185
Yeah I beat on it, but I didn't know I didn't even have a drop of coolant, I thought there was just air. So I didn't help the situation. I just added a full gallon of 50/50 last night. Slowbalt was thirsty
Posted from Cobaltss.net App for Android
Old Nov 5, 2012 | 11:01 AM
  #186
wayfarer's Avatar
without going back and looking again, it seems like you ran your best times when the engine was warm. Looked to me like leaving @ 170ish was the best, soooo.....
that's what a car wants anyway-- warm engine, warm oil, cold air, cold fuel.
Old Nov 5, 2012 | 11:20 AM
  #187
I'll definitely be going back for more practice
Old Nov 5, 2012 | 11:24 AM
  #188
Funny stuff lol
Old Nov 5, 2012 | 11:47 AM
  #189
Didn't say I was going to take .25 solely by cleaning my tires. I gave a list that Would've given me a better shot
Old Nov 5, 2012 | 11:58 AM
  #190
Add header, downpipe, and tb. That will give you another shot. The stuff you listed isn't going to make a big difference.
Accept what you ran and move on.
Last edited by chevygirl2006; Nov 5, 2012 at 11:58 AM. Reason: Automerged Doublepost
Old Nov 5, 2012 | 12:10 PM
  #191
padlock's Avatar
rocks in your tires wont make a darn bit of difference
If it was really an issue you would be spinning through gears due to this massive amounts of rocks impeding your traction (which doesnt seem the case, you dont have enough power for that.. no offense). And if you were spinning money bets the rocks would fly right out of the tread anyways
Old Nov 5, 2012 | 12:40 PM
  #192
wayfarer's Avatar
is there a way to control the shift points ? Tune? B&M shift plus?
what rpm are you (the car) shifting at, and what rpm are you crossing the line?
Old Nov 5, 2012 | 01:09 PM
  #193
newt's Avatar
Just manual swap the thing and call it a day.
Toss some slicks on and go cut 1.7-1.8 60 foots.
The lower 60's and the better gearing, you should be able to crack off a mid 14.
Ditch some weight/add some suspension mods and do a few more bolt on's and you can easily run a high 13.
Its not rocket science, dispite what people think you don't need 300whp to run a 13.
Hell my car doesn't even make 200whp and it runs LOW 13's. (mind you its about 400lbs less than a Cobalt).
Old Nov 5, 2012 | 01:32 PM
  #194
It would probably cost more than the car is worth to do a manual swap
Old Nov 5, 2012 | 01:33 PM
  #195
I've been looking into a manual swap. I've got a family friend that would do it pretty cheap.
I already am tuned with Trifecta. It's an automatic so it shifts based on the tune, which changed the shift points to about red line. And I didn't look at my tach when I crossed, but seeing as I finished at about 90mph, that would tell me I crossed around 5600 rpm, because it shifts again at 120.
Old Nov 5, 2012 | 01:37 PM
  #196
Just trade the car in for a lnf or lsj
Old Nov 5, 2012 | 02:04 PM
  #197
wayfarer's Avatar
do you know where you make peak torque? I can only assume that the shift points are programmed at peak torque. If you're not crossing the line at peak torque you tire size/gear ratio is off
Old Nov 5, 2012 | 02:07 PM
  #198
wayfarer's Avatar
naw.... ported lsj head / forced induction / nitrous on 2.4 bottom end
Old Nov 5, 2012 | 02:10 PM
  #199
I was saying if he wanted a manual to trade it in for one of those
Old Nov 5, 2012 | 03:09 PM
  #200
I don't have the money to trade in for an lsj/lnf.. I got the car for $5,000 as my first car a year and a half ago, from a family friend's salvage yard. rear end damage. I doubt I could get a lot more than $3,000 for it. I can do a manual transmission swap for about $1,000-$1,200 including the transmission. I swapped my 109k '06 2.4 engine for a 60k '08 2.4. The body of the car is nearly identical to how it looked when I got it.. 20 footer.... at night [:
Vince from Trifecta did it, I went through a dealer for $250. I don't know too much about my peak tq/hp because I haven't dynoed.
