Air box mod?
Hi guys this is ownedbyagirl?'s boyfriend.
I have a question.... In the 2.4L Cobalt the intake is on the front. I was thinking get a 3 inch tube, Bent it and connect it to the stock air box. As she just bought a K&N replacement filter.
She knows that she won't see a huge increase in HP or Economy unless she goes with the Cold Air Intake.
That a side I was thinking would this clean up some restriction?
I was thinking it would be temporarily fix. Since the MAF is connected to the Box part.
Please let me know your Input on this small MODIFICATION.
Again ,
Throttle body with Bent 3 inch tube to Air box with K&N Replacement filter.
Could this be less restrictive?
Again ,
it may be slightly less restrictive yes, you could the intake quite a bit more after i did it.. heres a thread i made on it..
How to make a custom intake utilizing stock airbox
but just being honest with you, just keep it stock until she gets an intake.. saving up pays off
What about this guys?
- LE5 High Flow Intake Tube #06-02-00690
What if I get this then hack saw the MAF adaptor and then on the end of that put a cone filter on!?
It's easy to take out.
https://www.cobaltss.net/forums/how-...ictures-64690/
You won't have any problem with water unless you try to cross a river.
Update: Boyfriend took out the silencer thing.
I took it for a test drive and its sooooounds soooo AWESOME.
FOOT RESPONSE IS BETTER BY 10 - 15%
Pick up and go way better!
I recommend doing it!
