anybody have this downpipe?
Old Feb 10, 2008 | 12:33 PM
omgshesaboy's Avatar
this downpipe looks pretty legit and seems like it might be a good buy.. seems to me like it should sound pretty good too, anybody have it though?
tell me what you think guuys
http://www.exhaustdepot.net/doforpahe.html
Old Feb 10, 2008 | 12:34 PM
BOOSSTED 06's Avatar
the only header it will mate up to directly is the pacesetter because of the ball flange
Old Feb 10, 2008 | 12:36 PM
i realize that.. my main concern is how does it sound.. i hate raspy exhausts. i would be embarrased to drive my car if it soundy raspy and shitty, so i want to have a fulkl exhaust that sounds "good"
Old Feb 10, 2008 | 12:39 PM
its catless, it will still have rasp even with the resonator, just might not be as harsh.
anytime you go catless you risk rasp and the only way to know is to try different combos
Last edited by BOOSSTED 06; Feb 10, 2008 at 12:39 PM. Reason: Automerged Doublepost
kingg5's Avatar
We came up with a direct fit downpipe that will bolt up to your pacesetter header. The DP is 2.5" and instead of using the balljoint connection which the header is designed for we went ahead and used a flex instead. The flex is superior to the balljoint design being that it gives you less stress on the manifold.
Old Feb 10, 2008 | 12:40 PM
D4u2s0t's Avatar
then i would ditch the pacesetter before you put your header/downpipe on. when i had my 2.2, i LOVED the pacesetter by itself. put on a downpipe, holy hell was it raspy as ****. i drove like a gradma because it was so embarassing. had a resonator welded in, and it was still terrible, but it was better.
Old Feb 10, 2008 | 01:07 PM
^^ty this is the most help i have recieved on this thread and it still doesnt answer my questions.. do you guys think this is a good dp or no?
bumpty.. i just bought a gmpp exhaust 5 mins ago
Last edited by omgshesaboy; Feb 10, 2008 at 01:07 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 01:12 PM
originaladrian's Avatar
tht is the EXACT problem i have now. I think im just going to put the stock DP back on. but it is very restrictive.
Old Feb 10, 2008 | 01:17 PM
well i just spent 400 on new exhaust.. but i still want to know.. DOES ANYBODY HAVE THIS?
Old Feb 10, 2008 | 01:23 PM
Z Speed's Avatar
ive got zzp shorty header, zzp catless downpipe, and megan racing cat back. Only time i get rasp from the exhaust is when its cold.
Old Feb 10, 2008 | 01:26 PM
WhiteSSBalt's Avatar
Not a Sebring
i <3 my rasp
alright.. well so if your zzp catless had a resonator wouldnt that rasp be taken care of for the most part?
Old Feb 10, 2008 | 01:33 PM
Z Speed's Avatar
i already have a resonator that came with the megan cat back but im sure if i had another resonator in there it would probably help tone the exhaust down a lot. Eventually I wanna get the zzp 3 inch exhaust cause i wanna upgrade to there stuff and i feel in the future im justified for a 3 inch exhaust.
Old Feb 10, 2008 | 01:34 PM
D4u2s0t's Avatar
i have a catted zzp header/dp and a magnaflow, and there's zero rasp anywhere in the rpm range. don't know about the catless though.
Old Feb 10, 2008 | 01:39 PM
Z Speed's Avatar
cat converters are over rated lol.... if it werent so cold right now i would get some friends together to take some videos of me doing fly bys. but its like -5 with a wind chill setting the temp to -30 -45 degrees
Old Feb 10, 2008 | 01:43 PM
tlax23's Avatar
werd.
This is my exact setup also. Im not sure about the one you posted, but you might want to check out zzp.
i didi.. believe me i have checked out all the setups i just wanted some info on this
Old Feb 10, 2008 | 02:25 PM
corect but it only fits the pacesetter, its a type of ball joint. I can read
Old Feb 10, 2008 | 02:53 PM
IonNinja's Avatar
assuming you've got a resonator on your catback and then a muffler as well it should be fine....didn't know these even existed
i wonder if using this DP will get rid of the exhaust leak sound i've had since i put my Pacesetter on...wish it was out before I ripped up my stock exhaust though!
Old Feb 11, 2008 | 12:49 AM
bump.. what do you guys think about this setup:
GMPP EXHAUST, THIS DOWNPIPE, PACESETTER HEADER
tell me how you think thatll be
Old Feb 11, 2008 | 01:00 AM
cobalt_driver's Avatar
idk, i know alot of people that love the zzp. there was a guy that had the gmpp, n i believe zzp header, n dp? n he said it was loud, but not raspy. idk, i'm not spending too much money on my header bc i will b going turbo.
Old Feb 12, 2008 | 10:22 PM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
