bigger throttle body?
Old Nov 19, 2010 | 04:10 PM
etnies's Avatar
ok guys just a quick update. ordering the zzp supercharger in a couple months but i have a quick question. if i put a bigger throttle body and cams and valve springs would i need a hp tuner? the charger comes with a modified ecu but im not sure it still be the proper air/fuel mixture after adding cams and what not...
Old Nov 20, 2010 | 01:31 PM
laser_racer's Avatar
You already have to switch to a lsj throttle body don't you? If you really want bigger then that ls4 is next and that needs some hp tuner work.
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
