Block heaters?
Old Jan 27, 2008 | 08:53 PM
rayrayjrc's Avatar
Block heaters?
Ok, I live in hawaii. And am moving to alaska. So my question is... Do i need a block heater, and if so where can i get one for my 07' cobolt ss/na.
Thanks for anyone that can give me any advice or help with this.
Old Jan 27, 2008 | 09:50 PM
Renesis's Avatar
nah you don't.. I don't have one and it gets friggin' cold here, just try to protect the car from the wind at night, let the coolant heat up a little before starting to move (I usually let it go up to 0C)
Old Feb 7, 2008 | 11:16 PM
outtamymind's Avatar
you should have a block heater already in the vehicle. double check if you do it will be located near your passenger side strut
Old Feb 7, 2008 | 11:21 PM
firestorm's Avatar
anyone living in below freezing, needs a block heater if they like thier car at all.
just cause it CAN start, doesnt mean the car is happy about it.
Old Feb 10, 2008 | 01:24 AM
stlurbanpunk's Avatar
why the hell would you do that????!!!!!! gezze i live in missouri and i thought it was bad here....
good luck with with the install.
Old Feb 10, 2008 | 09:27 AM
CSM Huber's Avatar
Cool
Note: The optional block (coolant) heater for the 2007 2.4L has a thermostatically controlled 3 prong 120 VAC plug which does not heat (turn on) unless the ambient air temperature is at 0 degrees F or below. (according to the manufacturer's opinion as noted in their owner's manual)
Old Feb 10, 2008 | 09:56 AM
Mrmaasta's Avatar
Like Firestorm said!
Old Feb 10, 2008 | 10:36 AM
WhiteSSBalt's Avatar
Not a Sebring
Hawaii to Alaska eh? That kinda sucks. But at the same time in so damn envious, b/c i've always wanted to go to both of those places!! Good to see your gonna keep the SS though. Get the license plate "SNOWBALT" when you get there!!!
Old Feb 10, 2008 | 07:07 PM
Gturismo1's Avatar
It's a shame it doesn't work unless the temperature is -18C, if I remember it correctly.
Old Feb 10, 2008 | 07:14 PM
MasterMike's Avatar
Definitaly get one..The block heater helps keep the coolant warm for an easy start-up...Block heaters are primarily used for starting purposes at colder temperatures and can greatly decrease the warm-up time of the engine and the idling time that should be used. With the blockheater, less fuel is required to start the engine as the engine block is pre-warmed. Block heaters need only to be on between 1 to 2 hours to be effective.
You don't know what you're talking about..Windchill has nothing to do with that..Wind has a negative effect on living creatures, not objects...
Last edited by MasterMike; Feb 10, 2008 at 07:19 PM. Reason: Automerged Doublepost
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
90white240
Sep 14, 2015 09:51 AM
