a/c condenser and radiator bent back and need replacement
Old Jul 18, 2011 | 05:27 PM
CHEVRO_SS's Avatar
i hit some animal last night and bent the **** out of my radiator and a/c condenser. Im going to be replacing it tomorrow, i already got the a/c condenser and radiator ordered for me and im going to be replacing it myself...anyone know much about replacing this? if its a pain in the ass, or how i would go by doing it? or is there a how to?
Old Jul 18, 2011 | 08:51 PM
OttawaMark's Avatar
Not terribly difficult, front fascia has to come off, AC condenser and rad come off in one unit. 2 bolts for the AC piping, 2 top clamps holding it all down on either side of the hood clasp and 2 rad hoses (and 2 ATF lines in the auto) to loosen off, plus a couple electrical connections for the fans (which also pulls out with the rad/condenser) and it all comes out fairly easy. take your time and it will be a 3-6 hour job depending on ability/ experience.
Old Jul 19, 2011 | 01:52 AM
Dee_Balt07's Avatar
If u got a jack, jack stands and don't mind laying on your back u can also pull it out the bottom and save some time. Took me 2hrs to do it this way which is what a shop will charge you. Good luck.
Old Jul 19, 2011 | 02:02 AM
Dee_Balt07's Avatar
One more thing. Incase u haven't loss all your refrigerant(spelling) be careful when disconnecting the a/c lines. Wear safety glasses or use a rag to cover the fitting. It WILL spray everywhere. Or if u find an ac shop just take it to them and have them recover your refrigerant(safer approach) and them refill it after you've replaced your parts.
Old Jul 19, 2011 | 03:01 AM
CHEVRO_SS's Avatar
thanks for in the info! can i just remove the top grille and then remove the radiator that way?
Old Jul 19, 2011 | 01:20 PM
Dee_Balt07's Avatar
Doubt it but u can give it a shot. Gonna take a lil longer tho.
tomj77
Oct 2, 2020 05:36 PM
Dustonian131
Sep 23, 2015 08:03 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
GM_Mike
Sep 19, 2015 02:43 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
