CA freeflow DP=should I gut it????
Old Feb 15, 2007 | 09:45 PM
g5mike's Avatar
I clogged my cat on the cobalt addiction dp instead of putting my stock downpipe back on,could I gut the cat? and has anyone else done this?
Old Feb 15, 2007 | 09:50 PM
OniMirage's Avatar
would get the ca high flow if I was forced into it or if I didnt need to be thrifty with my cash
Old Feb 15, 2007 | 09:52 PM
g5mike's Avatar
I have the free-flow cat,now that it is clogged I'm thinking of gutting it,esencially making it catless
Old Feb 15, 2007 | 10:04 PM
intense_SS's Avatar
i already told you once mike gut that ******* ****!!!
Old Feb 15, 2007 | 10:06 PM
Cobalt_SSTuner's Avatar
lol, yea, I'd gut it, see how it runs, if you get a CEL, then go with a high flow like OniMirage said.
Old Feb 15, 2007 | 10:08 PM
g5mike's Avatar
If I get a CEL I'll just you hp tuners and permanetly turn it off, I just need some hoeto on this before I gut it
ItalianJoe1's Avatar
You guys are not listening. He already clogged up a high-flow. Straight pipe FTW.
Old Feb 15, 2007 | 10:10 PM
nramlow2006's Avatar
id gut it...
Old Feb 15, 2007 | 10:12 PM
g5mike's Avatar
Originally Posted by nramlow2006
id gut it...
I agree,why buy a new one,if it sounds like ****,I'll put my stock one back on
Old Feb 16, 2007 | 08:28 AM
distillion's Avatar
I hope mine doesnt clog.
Old Feb 16, 2007 | 08:29 AM
06blackg85ss's Avatar
there ya go.....
but yeah it was brand new and only on the car for a few days...
Did you break it in properly? needs like up to 500 miles of easy driving to do so...
if not like what happened to darksuns first one... clog city.
and for those that are getting scared (which is common in this place)
they are fine if broken in properly.. mine has been on my car for almost a year now and 15000 miles and it's still good as new.
Last edited by 06blackg85ss; Feb 16, 2007 at 08:29 AM. Reason: Automerged Doublepost
Old Feb 16, 2007 | 08:33 AM
DarkSergeant's Avatar
On the CEL - you can buy MIL elimintors online or read up and make your own. Disabling the CEL in general might be a bad idea in case you have another problem.
Also, I'd look at a test pipe instead of gutting the cat. When you gut the cat you won't have free flow as your exhaust will be swirling around in all that open area. A lot of test pipes are also built to resonate, I had a magnaflo testpipe on my old Cougar and it sounded purty good..
You may also want to try to figure out why your cat is clogging before doing anything. They sholdn't clog for nothing, may be letting oil through or your mix could be rich.
Old Feb 16, 2007 | 08:40 AM
CTCOBALTSSS's Avatar
Originally Posted by 06blackg85ss
there ya go.....
Yes they are. I broke mine in for about 500 miles. Mine is fine.
That sucks Mike. I hope everything works out. The DPs are cheap. Maybe just buy a catless DP from CA.
Old Feb 16, 2007 | 08:41 AM
Darksun's Avatar
I was gonna post up here since i sold you the cat But i sent you a PM instead. Also about that gutting the cat issue if you saw the size of the highflow cat gutting it wouldn't mess up the air flow that bad. whats worse ceramic honeycombs in the way of the exhaust flow or a slightly open space flowed back into an exit. Now if it was the stock cat maybe i would say yes cause the inside diameter on the stock cat is huge. **** like this happen in the quest for power with a cobalt. I of all people know this more than most. Sorry about the clogged cat mike.
I think what did him in is that i gave him the cat too new. I didn't have a chance to break it in my self before i took it off and it sat around for months. i should have told him to break it in
Old Feb 16, 2007 | 08:44 AM
Yeah it's all good. Rich tunes don't help cats either. DP break in FTW!
Old Feb 16, 2007 | 10:21 AM
g5mike's Avatar
well this is what happened,I'm runnin mega rich due to the "intake cam" hence how I clogged it in a hurrey
Old Feb 16, 2007 | 10:22 AM
distillion's Avatar
hmm interesting.
Old Feb 16, 2007 | 11:02 AM
If you're running that rich, I'd jus put a test pipe on, I think you'll prefer that over gutting. Gut it first and see what you think.
Do you not have to e-test?
SmitBag
Sep 7, 2016 08:05 AM
cashstacker
Jul 4, 2007 04:27 PM
jgarciarivera
Jun 15, 2007 01:05 AM
selfinfliction
Nov 18, 2005 02:37 AM
