CA header and Down pipe!!!
Old Oct 24, 2008 | 11:45 PM
bbowman2002's Avatar
I installed the header and down pipe and I had to suck the cat back exaust forward 2" which created a angle on the down pipe collector that creates a bad exaust leak. Also had to cut some of the heaat shield around the Cat that was hitting the sway bar making bad a vibration. Has anybody had this problem? Or is it something I should bring up with the company? I am about to take the car to an exaust shop and have them add pipe and bends to fix the problem. But defeats the purpose of "bolt on"!!!!
Old Oct 24, 2008 | 11:48 PM
JimzSS's Avatar
is the catback aftermarket and if it is how did it fit with the stock down pipe and manifold?
Old Oct 25, 2008 | 12:43 AM
iLLmaTic3s's Avatar
there is no need for moving the catback...and it shud clear just fine of the heat shield and or any suspension..take pics and email or call c/a
Old Oct 25, 2008 | 11:34 PM
the down pipe was the one that was on the CA website. When i installed it I did the header and the down pipe together. When I matched the stock down pipe to the new one they looked like they matched! I was going to put the stock header back on to see but whe I pulled it off I noticed a crack so I didn't want to put it back on...
hacadacalopolis
Oct 28, 2015 06:09 PM
717ssbalt
Oct 2, 2015 04:01 PM
z28addiction
Sep 28, 2015 12:03 AM
