CA header or GMPP header?
Old Feb 16, 2007 | 08:02 PM
mike25's Avatar
so which one should i go with....?....and do these headers make a noticeable difference in sound?.....any one with experience on these personally?....and also where is the cheapest place to get them?
Old Feb 16, 2007 | 08:09 PM
Red2.4SS/SC's Avatar
cobalt addiction header is way better than the gm one the gm header is only increased flow by 30 cm
Old Feb 17, 2007 | 08:09 PM
iLLmaTic3s's Avatar
cobalt addiction header..but do u wanna keep ur warranty if anything mite go work with the C/A header and damager your car. but yeah u will get better flow with the c/a, not gm.
Old Feb 17, 2007 | 08:20 PM
MISSMATCHEDFACES's Avatar
i have the cobalt addiction header, definatly the way to go.....the tubes have a better flow, good ****
Old Feb 17, 2007 | 08:26 PM
stotte20's Avatar
you can get both from cobalt addiction.
Old Feb 17, 2007 | 08:28 PM
Jackalope's Avatar
I've heard the CA header doesn't fit 100% and you may have an issue with heater hoses or something. If anyone with the header can clear this up it'd be great.
Old Feb 17, 2007 | 08:42 PM
yes, it does press slightly against the coolent hose on the back of the engine forcing the fluid to come out, needed to be headed and slightly formed
Old Feb 17, 2007 | 08:43 PM
Jackalope's Avatar
On a scale of 1 - 10 how bad is it?
Old Feb 17, 2007 | 08:48 PM
06blackg85ss's Avatar
well I have it on my car and no fitment problems... but if you do, you can rotate the coolant line so it doens't make contact... no big deal at all..
Old Feb 17, 2007 | 09:00 PM
yea, u can rotate it, did the form just to be sure
Old Feb 17, 2007 | 10:40 PM
mike25's Avatar
so did it make the car sound any better?.....also is there a notcieable difference in performance?
Old Feb 17, 2007 | 10:43 PM
power gains from a header are never rlly huge, u mite get like 5 - MAYBE 10 hp out of it...id say at the best 5 - 8.....but sound wise...makes it a lttl deeper, should go with a downpipe to though to get the most out of it, with an exhaust of course
Old Feb 17, 2007 | 11:19 PM
iLLmaTic3s's Avatar
kenny tested his header on a 2.4 in a HHR and it put down 10whp.
Old Feb 17, 2007 | 11:20 PM
ah, rlly damn....good ****
Old Feb 17, 2007 | 11:23 PM
stotte20's Avatar
the fitment isssue is only for the 2.2 seen this in one other thread
Old Feb 17, 2007 | 11:26 PM
yea, cuz the 2.2 has the air return valve, noone makes a header for the 2.2
Old Feb 17, 2007 | 11:31 PM
iLLmaTic3s's Avatar
u can put on the GM one and shud not have a problem. its a good design of a header and really affordable(c/a stuff). i will prolly have it on my car too, soon. cant beat havin them just down the road.
Old Feb 17, 2007 | 11:34 PM
the gmp header looks exactly the same as the stock ss s/c header when i took it off, when i had the 2.2, didnt look like they put to much effort into make that header, with the dents in it an ****
Old Feb 18, 2007 | 11:59 AM
iLLmaTic3s's Avatar
if u put a lsj header on a 2.2. that wub a big difference for a 2.2. but the GMPP one is not the best header for gains for a 2.4 or 2.0.
Old Feb 18, 2007 | 12:15 PM
if u put a gmp header on a 2.2 ur gonna throw a code....because u have to unhook the air return bullshit valve
Old Feb 18, 2007 | 12:32 PM
only on some of them (cali emissions)
Old Feb 18, 2007 | 12:34 PM
yea, i got stuck with one of thse bastards when i had my 1st cobalt
Old Feb 18, 2007 | 01:26 PM
rlinden86's Avatar
gm header
the gm header is the same as the 2.0 header cast iron but that gm header is extrude and honed more. but its a waste so go with the cobalt addiction one i am.
ryan.
Old Feb 18, 2007 | 04:59 PM
gocanucksgo's Avatar
I've got the GMPP Manifold...it's not a waste to me at all, I could feel the difference when i first put it on, sounds great and no warranty or fitment issues.
Old Feb 18, 2007 | 05:17 PM
waranty is the only reason to get the gmpp... anything else will out flow it, but runs the chance of having your warranty voided
