Cam sensor problems.
Old 01-11-2014, 09:27 PM
Doony's Avatar
Question Cam sensor problems.
Ok, so I've had a intermittent problem with my intake cam sensor for awhile now. I switched it with my exhaust cam sensor then it gave me codes for the exhaust. I've now put a new sensor in for the exhaust but its having a hard time starting. engine light is saying its the exhuast sensor. It runs perfect once its started, unlike before when it would stall and sputter. anyone have this problem?
Old 01-12-2014, 10:14 AM
Spawne32's Avatar
what codes exactly are you getting? You said you switched sensors and it moved with the sensor, which indicates a bad sensor, its possible you received another bad sensor. What part# did you replace it with? Should be ACDELCO Part # 2131690
Old 01-12-2014, 03:40 PM
Doony's Avatar
I cant check the part number right now. But its not an acdelco, its a BWD think thats the problem? Ill try switching them again tomorrow see if it is another bad sensor.
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
HEATON
10-16-2015 07:21 PM
nathan112i
09-30-2015 07:12 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Cam sensor problems.
