Camshaft question
Camshaft question
Does anyone know if the blank ecotec camshafts from gm can be used for a custom grind for the LE5. I know on crate engine depot they have the parts listed for the 2.0 and 2.2 only but I just want to verify for sure that they can't be used for the 2.4
I checked on the gm site and it didn't list which engines they could be used for.
They say only the LNF (for Forced Induction) and LE5 (NA) VVT cams swap. Good luck with your cam project. What are you trying to achieve with the custom grind? higher lift / lift rate / duration ....
Iceberg
Sep 29, 2015 12:33 PM
