Can the LEA block be re-sleeved?
Old 04-20-2018, 07:01 PM
Henry3959's Avatar
This looks like a very easy process with the proper Kent-Moore tool.
Old 04-20-2018, 07:58 PM
jdbaugh1's Avatar
https://www.youtube.com/watch?v=BtsVlj3n-OQ
I had my LSJ block re-sleeved though the machine shop didn't have this tool and I think this tool would have been easier than the way they did it. I think either Mr. Beleveder on here or Mongorat, Jeffery Reiland on facebook, or I'm sure you have your own channels but their are stock style sleeves available that are supposedly a better alloy and much stronger though I don't know much about them. Pretty sure you can resleave an LEA block the same way but the tool is expensive unless you can find one to borrow.
Old 04-20-2018, 08:39 PM
Henry3959's Avatar
I'm working with Jeffrey already on how to solve this. Both the Diamond pistons and LEA block are from him. and I have .005" PTW in the virgin part of the block and cylinder 4 has .0072 at the top without touching it. #4 has .0022 taper which is why I am thinking about relining it.
Old 04-21-2018, 12:08 AM
Slobodan Milošević
07blackg5's Avatar
Only the gen 1 and 2 blocks have the replaceable sleeves that use the Kent moore tool.
The gen 3+ blocks have non pressed in liners that are "non serviceable". Rencently, people have started machining out the liners and retrofitting pressed in sleeves to the gen 3 block structures.
It's doable, yes. But it's not as simple as pressing out the old sleeves and installing new ones
jdbaugh1 (04-21-2018)
Old 04-21-2018, 03:33 AM
Henry3959's Avatar
Well, there goes that option....
Old 04-21-2018, 01:46 PM
chevygirl2006's Avatar
It’s possible but not even Trevor jolley likes to do it. And he makes sleeves. There’s barely any material in to work with. I have the LEA block in mine and I wouldn’t bother sleeving it. It can hold a lot of power without them.
Old 05-10-2018, 09:59 AM
mrbelvedere's Avatar
bore it enough to make all the bores the same then buy a new set of pistons y0u can resleeve a gen3 block but it would be cheaper to bore it and get new pistons
Old 05-10-2018, 10:04 AM
Henry3959's Avatar
That's what I did.
Dished pistons, compression height is 1.082in with an extra .020 valve relief. MO BOOST!
Old 05-10-2018, 11:32 AM
so you went with low compression for an SC build?
Old 05-10-2018, 11:33 AM
Slobodan Milošević
07blackg5's Avatar
Old 05-10-2018, 01:39 PM
raise the compression run a bigger pulley make mo power
07blackg5 (05-10-2018)
Old 05-10-2018, 11:03 PM
Henry3959's Avatar
No...
The 1.082 compression height and .010 off the deck puts that pistons back to the same height and squish. Diamond's dish is a meager .020" at the center with soft edges to aid in a more efficient burn only. The .010 off the head wasn't in my plans but I have decided to stick with the OEM gasket. With the effective volume of -3.0cc we are calculating a 10:1 CR with plenty of room for additional valve lift in the larger reliefs. If this wasn't a VVT engine I would have changed the cam timing. It's still a fair weather DD. Actually been enjoying driving the H2 again.... just not washing the beast.
Remember I'm at an air pressure disadvantage here at 6000'+ ASL
Old 05-11-2018, 03:37 PM
I would think with the altitude disadvantage and you being SC you would want to go somewhere closer to 12:1 to actually make some decent numbers.
Old 08-19-2020, 03:10 AM
tolikmelnikov's Avatar
Let me ask you a question. I have a 2012 Chevrolet Equinox 2.4 there is a LEA unit. Can I replace the sleeves on it, or is it 3rd generation and is not repairable? If a block needs to be bored, where can I buy a piston and rings with the appropriate oversize? Thanks for any information!
Old 08-19-2020, 09:44 AM
gen3 blocks are cast in place no replacement sleeve available unless you have custom sleeves made and put in
Old 08-20-2020, 04:10 AM
Are the LEA engine blocks definitely not repairable?
In this case, give a link to a site where you can buy pistons and rings oversized after boring the cylinder block. Thank.
Old 08-20-2020, 07:31 AM
Any piston company can make oversized pistons
terry11
10-09-2014 11:09 AM
mongorat427
01-24-2013 07:17 AM
Killa SS
01-16-2013 07:37 PM
kxrida2000
12-12-2012 10:28 PM
turbobc2balt
11-25-2010 02:27 AM
Quick Reply: Can the LEA block be re-sleeved?
