can a ls4 tb work with the 2.4
the one for the le5 is for the stock lsj and if you are supercharging with the lsj supercharger it would work because you have the lsj intake mani so for your supercharged 2.4l it will regular 2.4l it dont think it will
yes that is right on zzps website they have the specs on the 2.4l tb compared to the specs of the lsj tb i dont think that the ls4 tb will work because on zzps website they said you have to port the intake on the lsj to make the ls4 fit and seeing that we have plastic intake manis i dont think it will work
to the OP, you can run a LS4TB, but it will require the same rewiring that the LSJ TB does
actually the throttle body is a restriction it shows on zzps website that the 2.4l tb is smaller than the intake mani so using a bigger tb is going to free up some horses maybe not much but any gain is a good gain just bought an lsj tb and gonna buy the adapter next week to test it out
Anytime you allow the car to breath freely(or forcifully), you will gain more hp.
Although the 2.4TB might not necessarily be a huge or even a moderate restriction, its still a restriction.
I couldn't use the ls4 tb on my car. There was no way it would fit with the intake. The spacer plate just messed things up and the abs got in the way. Ended up having to trade a local member straight up for his lsj tb so we could get my car completed. I have an 07 auto, and apparently the engine is pushed forward some which would cause fitment issues.
