CEL from intake??
Old Oct 12, 2007 | 10:24 PM
CobaltChikara's Avatar
Question CEL from intake??
Just installed a Fujita CAI today, and after driving for a short period of time the CEL came on. How do I get rid of the CEL? could it be that i put the MAF on facing the wrong way? or does it not matter? I know that the 2.2 throws a CEL with the aftermarket intake because of the SAI, but havn't heard anything about the 2.4 doing the same. Can anyone help me out? any info would be much appreciated.
thanks,
Q
Old Oct 12, 2007 | 10:27 PM
Sunburst_SS's Avatar
well the maf is a directional sensor....so yes it matters which way it is installed.
Old Oct 12, 2007 | 10:28 PM
streetrcer909's Avatar
should of disconnected negative terminal of battery before installation and no cel would of came up not sure if it will make a difference now, i was informed to disconnect negative terminal before installation and i did so and have not had any problems try it now it may help
Old Oct 12, 2007 | 10:34 PM
D4u2s0t's Avatar
it's because the sensors are getting more air than what it's programmed for. double check to make sure that everything is tight and there's no leaks. it's probably the p0071 which plenty of people get. as long as it's installed properly, there's no leaks, and it's driving the same as it was, it's safe to delete the code and forget about it. you can try disconnecting the negative side of the battery for a few minutes, that should clear it if you don't have a scanner. it may or may not come back.
Old Oct 12, 2007 | 10:35 PM
which way should the MAF face? silver side forward? or black side? I disconnected the battery and it went away, but i haven't driven yet so i'm not sure if it'll come back. thanks for the quick replies already lol..i posted 5 min ago and check back and already three
Old Oct 12, 2007 | 11:16 PM
D4u2s0t's Avatar
isn't there screws in the hole in the intake that only let you put it one way? all the different intakes i've seen you can't put it in wrong because the holes won't line up.
Old Oct 13, 2007 | 12:28 PM
I just took a look at the MAF again and i noticed that there is a small arrow on it. i had it on correctly already so it's probably not that. After i disconnected the battery the CEL came back again ...I mean the car runs fine. I havent noticed it doing anything strange. It's just that the CEL bugs the hell out of me every time i look down at the gauges. I guess i'll just have to take it somewhere to get it scanned and have the code erased.
Old Oct 13, 2007 | 12:31 PM
D4u2s0t's Avatar
get yourself a code reader. you can get a decent one for around 100 dollars. you can scan your own codes, and delete them. if you plan on modding your car just spend the money and get one. it will avoid you having to post "hey guys, what's this cel from" many times down the road!
Old Oct 13, 2007 | 12:32 PM
chood711's Avatar
mine came on to after installing fujita. mine went away after a few hundred miles then came back on a few times and went away and hasnt been back on.
Old Oct 13, 2007 | 02:30 PM
Codyak Supercharged's Avatar
fujita a oiled filter?
clean the MAF sensor with electronic cleaner or maf cleaner
Old Oct 13, 2007 | 06:42 PM
yea I might just get a code reader myself. Yea i believe it uses an oiled filter. i was planning on switching to an aem dry flow filter or a steel mesh one because of the problems with an oiled filter. but yea..that's the thing i hate about newer cars..they're so sensitive to everything. thanks for the input guys. much appreciated
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
