Cleaning MAF.. Question..
Old Jun 4, 2009 | 10:09 AM
averagewhiteboy's Avatar
Hey,
How do you properly clean the MAF? I have a shifting issue, and I was told to try and clean it. It's inside an Injen CAI, so it's quite easy to get to. Just un-do the 2 bolts and wipe it down with parts cleaner or something? Do I just have to clean the part that sticks inside the tube or is there more? Do I have to do it with the engine cold, or is warm fine too?
Thanks guys..
Old Jun 4, 2009 | 05:04 PM
riko540's Avatar
I think there is a product called MAF cleaner that you use. I think it come in a spray can.
Old Jun 4, 2009 | 05:20 PM
Red07SSNA's Avatar
The factory service manual doesn't describe how to clean the MAF. Keep in mind that the only thing to clean is the heating element - do not soak the MAF in anything! The MAF works by sensing how much voltage is required to keep the heating element at a certain temperature. Oil can insulate the heating element and make it slow to respond to airflow changes while water does the opposite -- makes it respond too quick/incorrectly.
Old Jun 4, 2009 | 05:23 PM
riko540's Avatar
Whatever you do don't clean it with gas. Do that and you'll need a new one.
Old Jun 4, 2009 | 06:04 PM
reaper89's Avatar
go to the auto store and buy MAF cleaner. Heres what i have and use.
Old Jun 4, 2009 | 07:52 PM
Red07SSNA's Avatar
"Proven to Gain 4-10 Horsepower at the Wheels!*"
Clean it 3 times in-a-row and get 12-30 more HP ...JK
Old Jun 4, 2009 | 07:55 PM
myfakeevo's Avatar
just spray it and let it air dry. use that can thats up there in the picture
Old Jun 5, 2009 | 10:57 AM
So just un-do the two bolts, pull it out, and spray it down with the stuff..?
Does it have to be cool or can I do it at running temp..?
Old Jun 5, 2009 | 01:23 PM
reaper89's Avatar
Don't think it matters, just take I out spray it down let it sit and air dry and your done
Old Jun 6, 2009 | 05:08 AM
So I spent the 8 bucks on that stuff and there's no difference in the shifts. They're still hard and the initial shift lurches like crazy. I swear I have to be slowly breaking something..
Old Jun 6, 2009 | 05:50 AM
xCobalt05x's Avatar
it doesnt matter if the engine is warm or cold when you clean it. just let it air dry before you put it back in.
Old Jun 6, 2009 | 10:14 AM
Already figured that out. Last post. New question.
Old Jun 7, 2009 | 11:16 AM
Red07SSNA's Avatar
Have you looked for any codes stored -- gotten your OBD II scanned?
Old Jun 7, 2009 | 11:35 AM
Yup, and all it says is 02 sensor related stuff from getting the cat replaced. I ran catless for a few days. I guess I'll just have to go to the dealer because nothing else is working..
Old Jun 7, 2009 | 11:41 AM
red_line_cobalt's Avatar
are you stll in warrenty?
Old Jun 7, 2009 | 11:43 AM
Nope. Almost 60k. If I was I would've just went down. haha
Old Jun 7, 2009 | 11:48 AM
ha ok i thought i would check
Old Jun 7, 2009 | 12:02 PM
haha Yeah, been out for a little bit now. And my 4 years still isn't even up. haha Still got a few more months. So much for the 48k.. haha
Old Jun 7, 2009 | 12:12 PM
i am just the other way around.. my warrenty will end on time not milage.... i got 10,000 miles
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
grampss
Sep 27, 2015 08:51 PM
