CO2 - Meth - N2O - Nitro
Old Feb 12, 2009 | 11:14 AM
Dunkinuts's Avatar
Question CO2 - Meth - N2O - Nitro
Okay I am wondering what are the pros and cons for all three on a NA engine.
They all basically do the same thing, they cool the intake temperatures and makes the air more dense. Meth is the only flammable product due to the bit of alcohol that is in it, N2O itself is not as with CO2.
So on a NA engine what would be helpful? What would hurt?
Also looking at Snow Performance, they have a nitromethane additive to their water/methanol injection system.
Old Feb 12, 2009 | 11:16 AM
DarkCobalt13's Avatar
honestly dont think CO2 will help much unless your FI. Not sure about Meth. Obviously Nitrous is good ****, but dangerous if you are a noob....
Old Feb 12, 2009 | 12:51 PM
Dunkinuts's Avatar
What really got me interested is the nitro mixture that Snow Performance has that you add to the water/meth injection. I think that if I do that I will be the only one on that set up.
Does anyone know what (roughly) the stock A/F ratio is? also how hard is it to install a wideband?
Old Feb 12, 2009 | 01:24 PM
HunterKiller89's Avatar
stock or stage 2 tune?, and easy as hell...
Old Feb 12, 2009 | 01:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no meth on an NA engine-no need for it, co2 is usually used to cool intake charge temps on boosted cars, nitrous is a great power adder and i recommend it!
Old Feb 12, 2009 | 01:35 PM
ecotecon18s's Avatar
I wouldn't spray CO2 into the intake though...If im correct that would take the place of much needed oxygen for the combustion cycle...
CO2 would be more for spraying into your intercooler or one of those intake chiller boxes.
Old Feb 12, 2009 | 01:38 PM
Dunkinuts's Avatar
intake on a 2.4, check the section
The reason I was looking at the meth was simply so I could add the Nitro mixture. And it is cheaper then nitrous and from what I have read more "stable" also. Nitrous and Nitro don't need tunes and both work in the same ways. But Nitro is an all in one item where you have to "on the fly" mix nitrous with fuel. As of right now I am just trying to get info. I don't know of any cobalts that are on nitro no matter how little. But anyone with a meth kit could add nitro to it.
you don't there is a tear drop shaped thing that sits in the intake tube that you spray the CO2 into that chills the IATs
Old Feb 12, 2009 | 02:09 PM
lol. sorry, i roam around a lot.
Wouldnt meth have the added benefit of being an octane booster? so you can run more timing with meth, even when NA? You wouldnt really need a meth/water mix tho, since you wouldnt need water to do any cooling. Just straight meth
Old Feb 12, 2009 | 02:13 PM
BLAZIN07SS's Avatar
I'm too JDM for you
octane booster...eh, only a little higher. i dont even know how it would activate on an NA car since most are boost activated by the map sensor
Dunkinuts's Avatar
well it would be Snow Performance's Juice Boost so meth plus whatever they put in it. But again my main use for that would be to add the nitro into the mixture.
Old Feb 12, 2009 | 02:20 PM
why not just get a nitrous kit?...
Old Feb 12, 2009 | 02:22 PM
Dunkinuts's Avatar
I am looking at that also but right now the meth/water/nitro mix is 4-500 dollars cheaper then nitrous. It also isn't as common and seems more plug and play.
Old Feb 12, 2009 | 02:24 PM
Kibosh3's Avatar
meth alone does very little for NA engines... however, the proper mixture of water/meth doubled with n2o can do some very good things for you, (water injection helps to deter knock, fyi).
co2 will do very little for you, considering, again- you are only NA.
good luck
Old Feb 12, 2009 | 02:34 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i dont know man. i got my whole NX wet nitrous kit(big solenoids too good to a 250shot), purge kit, bottle warmer, switches and button for under $400. im on a 60 shot. i have to refill the bottle after i spray about 10-12 times for 25 bucks.
Old Feb 12, 2009 | 02:38 PM
Dunkinuts's Avatar
did you buy the kit used? And around here nitrous is bout 40 bucks for a 10lbs tank, last i checked.
Old Feb 12, 2009 | 02:41 PM
Kibosh3's Avatar
ya for me, it is around that price as well...but well worth it if you aren't trying to race everything on wheels...conserve and it'll last you months. (me ranging 1-3 months- then again, i rarely sprayed)
Old Feb 12, 2009 | 02:59 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yes it was used, only about a year old. the local shop only charges me $2.50 per pound
Old Feb 12, 2009 | 03:12 PM
Dunkinuts's Avatar
yeah I try and drive slowly, and if I get nitrous the bottle will not always be in the car. unlike with the meth/water/nitro mixture which will always be in the car.
Is it a base kit? I am pricing a new kit with some goodies. I have a thing against used products.
Old Feb 12, 2009 | 03:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
what do you mean by base kit? i dont have a WOT switch or anything. simple push button set-up
Old Feb 12, 2009 | 03:57 PM
Dunkinuts's Avatar
that is what I mean. I want all the safety features I can get.
Old Feb 12, 2009 | 03:59 PM
Kibosh3's Avatar
wot switches are easy to set up...just use that in place of your push-button...
Old Feb 12, 2009 | 04:10 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i have seen a lot of WOT switches fail. what the hell is gonna go wrong with a button?
Old Feb 12, 2009 | 04:23 PM
Dunkinuts's Avatar
I would get button happy, but I think the biggest reason I am leaning toward W/M/N is b/c i want to be different.
Old Feb 12, 2009 | 11:33 PM
mmcgee123's Avatar
just get nitrous and a good tune ull love it no regrets here
i have a button also i dont trust that WOT switch **** i kno when im pressin the button and i kno when im lettin off ha
Old Feb 13, 2009 | 12:27 AM
Dunkinuts's Avatar
I will wait until all these nitrous 2.4 guys run and see where they are at. Then I will make a final choice. So hurry up and get to the track guys.
